winterize the kubota
   / winterize the kubota #1
Rich 529
Pennsylvania
Kubota B7800
This is my first winter with the kubota
I live in western Pennsylvania
I probably will only use the machine to move snow during the winter months. We don't get tons of snow so I probably won't have a use for the machine every week.
I keep it parked under a roof, unheated.
What should I do to winterize the machine?
Does any one change any fluids before or after winter, not concerning the hour meter recommendations.
Thanks,
Rich
   / winterize the kubota #2
i would make sure your hydro fluid is super udt, not straight udt.
i would also run mobil1 turbodiesel engine oil --
-- make sure you have an antifreeze / water mix in your radiator -- not just water --
-- maybe get a block heater, too.
that's all.
   / winterize the kubota #3
I recomend a block heater.
My Kubota starts well in the winter but when it gets really cold and you don't have some kind of block heater installed they make sounds that they should not be making.
   / winterize the kubota #4
I always check the freeze protection level with one of the cheap suction bulb testers from the auto parts store. It could be catastrophic failure if it freezes. Lube the tractor and put in fuel conditioner. Put out a few mouse traps or use the spray rodent repellent it seems to work well (capsasin based). Clean machine of heavy dirt or mud that may hold moisture and promote corrosion.
   / winterize the kubota #5
Rich,
I would also keep it full of fuel and add some additive to keep the Diesel from gelling and raise the Cetane level to aid in cold starts. The additive piece seems to be hot topic here and you can find plenty of posts with members debating it. Power Service is one and easily available at Walmart and other auto parts stores. I have used Stanadyne for some time in all my diesel engines and it seems to work well. also, don't have link for it but there was a post maybe a couple months ago that had link to a study done on various additives and ranked them. You would probably find it doing search on additives.
   / winterize the kubota #6
I agree with everything said, also once started give the tracktor plenty of warm up time before operating to get the Hydraulic fluid pumping. Cold fluid even if SUDT may contribute to some strange noises. :)
   / winterize the kubota #7
yup- fuel treatment is your number one concern. Add power service and run it through the system so your fuel filters is protected as well. Check your radiator freeze protection level and top the fluids everywhere. Get the red bottle of 911 for those emergency gelling of your fuel or have 1/2 gallon of kerosene on hand . (I never had to use it since I been using power service). If you didn't switch to SUDT when you did the 50 hour service, I wouldn't worry too much about it. Add a couple sheets of bounce dryer sheets under the hood somewhere to keep mice out of there just in case. (be sure its not near or on hot surfaces)
   / winterize the kubota #8
Nothing new to say, really, but I'll say it again: Fuel Treatment.
After a couple of years of treating "winter" fuel, but not bothering the summer, and paying the price a couple of times, I found it was much easier to simply treat the fuel when I buy it, no matter the time of year. It gets you in the habit.
I don't use the tractor all that much, and fuel purchased in say, September, might still be in the tractor 2 months later. It's easier not to worry about it.
Block heater is a good idea, but probably not required. And, if you're going that far, a way to turn on the block heater without trudging outside in the cold.
Thanks for all of the advice, this is a big help. I'll do the fuel additive, the radiator has antifreeze in it.
BXRICK, i'll take your advice that the block heater is a good idea, but probably not necessary. I'll see how the first winter goes. Anyway, is a block heater something that I can install myself or is it a dealer job?
I have not approached the 50 hour mark yet. When I do it seems that I should put in SUDT. I will also do the dryer sheet. I never thought about the mice.
Should I remove the battery like I would in a gasoline car engine?
   / winterize the kubota #10
The block heater is an easy job assuming you have the right size allen key, 17mm I think. Its large! if you can drain your coolant, and have the allen key a cheater bar, and 45 minutes, then you can install the block heater... Good luck.
Makes a world of difference in the winter!!!
Komatsu Midi Excavator (A51691)
Komatsu Midi...
ABI TR3 LOT IDENTIFIER 134 (A53084)
ABI TR3 LOT...
ECHO SRM-225 GAS WEED EATER (A51248)
ECHO SRM-225 GAS...
18 Front Suitcase Weights with Brackets (A53472)
18 Front Suitcase...
1264 (A50490)
1264 (A50490)
2019 Ford F-550 4x4 Ext. Cab Chipper Truck (A51692)
2019 Ford F-550...
