winterize the kubota
   / winterize the kubota #21
bpattie said:
Power Service is one and easily available at Walmart and other auto parts stores.
I use the white bottle the year around.
1*Add power service
2* 1/2 gallon of kerosene on hand .
3* (I never had to use it since I been using power service).
1*Use White bottle of PS.
Here is the mix or mixes I use.
55 gallon of diesel add 1 quart of PS.
30 gallon of diesel add 16 oz of PS.
5 gallon of diesel add 3 oz of ps.
2*Treat the fuel with PS and forget the Kero.
3*Putting Kero in winter blend is not a good idea because winter blend already has had the kero added to it.
Putting your own kero in the diesel results in to much kero in the diesel .
It's kinda like buying pemixed anti freeze and mixing it half and half with water so you wind up with a dulited product that's harmful to your motor.
1*I found it was much easier to simply treat the fuel when I buy it, no matter the time of year.
1*Also much better .
Should I remove the battery like I would in a gasoline car engine?
I start mine up on the 25th of each month and let them run 15 to 20 minutes?
Would be kinda hard to do with a removed battery dontcha think?:D
Here in drought stricken Central Texas.. I have done everything as folks up north..except a fuel additvie -
1* Should I? Texas winters are light by any standard...Thanks
Yes cause you don't use additives like PS just to combat cold
1*I've never treated my diesel fuel but make sure you don't use summer bought diesel in the cold, cold winter.
1*The only difference between winter and summer blend is the amount of kerosene in the fuel.
All 3 of my of my BXs ran just fine last winter on summer blend.
Summer blend is what I had on hand when winter hit the front door.
I had treated the summer stuff with 1 quart of PS per 55 gallon of diesel and it worked fine all winter long.
1*I always assumed topping off was best but then after reading some unrelated posts that diesel fuel can start to have stuff grow in it etc.
1*Water in the fuel causes that stuff to grow.
Keeping the tank topped off helps reduce water accumliation.
Again there there are additives for combating that stuff also .
2007 Ford Escape SUV (A51694)
2007 Ford Escape...
2012 Seal Rite SR 1000, Tandem Axel Trailer  (A52384)
2012 Seal Rite SR...
UNUSED JCT HYD AUGER (A51248)
UNUSED JCT HYD...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A52377)
2003 Big Tex 10PI...
NEW Wolverine 72'' Skid Steer Tiller (A53002)
NEW Wolverine 72''...
