Ford 1700 4x4 Diesel
   / Ford 1700 4x4 Diesel #1
ew6071
This is a 2 Cyl and will not turn over?
Thanks Ernie
   / Ford 1700 4x4 Diesel #2
can you elaborate some?
   / Ford 1700 4x4 Diesel #3
Lots of things can stop it from turing over. What have you done so far to diagnose the problem? Have you checked the battery? Seat switches? Tested the starter? Do you know if the motor is locked up?
The more info you give the better the people here can help you figure out whats wrong.
   / Ford 1700 4x4 Diesel #4
ken,
The only safety 1700 has,is a Neutral safety switch (clutch pedal activated). I start the investigation from battery to starter and then to fuel system. I take the dip stick out for oil or lack there off and also check for antifreeze in the radiator.
JC,
Thanks Ernie
Hello to all, I am looking to buy this tractor. The guy that is selling it say's that he bought it from a guy sight on seen,and that it had run out of fuel. He got it home and bled it and hit the key and it just went clunk. I have not seen it yet I was just trying to get some ideas of what it could be, if it is something common with these 2 cyl or what else it could be.
Thanks Ernie
   / Ford 1700 4x4 Diesel #6
Dead battery, poor battery cables or connections, fried starter or solenoid, motor froze up, broken crankshaft. Lots of possibilities people would like to help you with but need more info.
Jim
   / Ford 1700 4x4 Diesel #7
Thanks Ernie
Ernie,
Information is tricking down pretty slowly. Do you know the difference between gas and diesel engine and basic start up for each?
JC,
Red Iron Oxide in Trace Mineral Supplements for Cattle
Red Iron Oxide in...
GENIE MAN LIFT (A52472)
GENIE MAN LIFT...
2009 Freightliner M2 106 MedTec Ambulance (A51692)
2009 Freightliner...
2013 International DuraStar 4400 Altec AM547 50FT Material Handling Insulated Forestry Bucket Truck (A51692)
2013 International...
GORBEL EASY ARM LIFTING ARM (A52472)
GORBEL EASY ARM...
Danuser Digger F-8 (A52748)
Danuser Digger F-8...
