block heating on Foton 404
   / block heating on Foton 404 #1
gcmedica21
Sadieville,Ky
Europard Foton 404
Hello Everyone,
Longtime reader, first time poster. Because of this website is why i purchased my Foton. Very new to farming. I have a used 2005 Foton 404 with about 140 hours, my first tractor :eek:. I searched and found no answer so if there is one i am sry.
Last winter i killed my battery trying to start the tractor to scrape snow off of drive way. I tried little magnetic heaters and also a small space heater with no luck. I did use my glow plugs as well but it seems to be a slow process, unless i am not doing it right. (hold it down for about 30 seconds and repeat :confused:).
Anyway, what i am wanting to know is......is there a "freeze out plug" on these tractors? If so where is it? I have looked and cannot locate it. Also, if there is not a freeze out plug will one those radiator heaters i see at tractor supply work? One of those that you cut out a small section of radiator hose and hook it up.
I do keep my tractor in a pole built barn with out insulation. Any questions and any input would be very much appreciated. thanks
   / block heating on Foton 404 #2
Yeah, there are frost plugs on the engine block, but those kinda heaters scare me. I have visions of them popping out while I'm working. Many folks who take that water route put in a lower radiator hose heater. Personally I prefer an oil pan heater. I've had them on three tractors now, never had a lick of trouble starting any of them, and I've seen it as cold as -7F over this way. Both my current diesel tractors start ok down to about 20F (one with glow plugs, one without), then they get sluggish. Same with my old Mercedes turbo diesel. So when the weather weenies predict overnights into the teens or lower, I plug in all three.
Both my current tractors have a split oil pan that accommodates the front drive shaft housing. I use a pair of Wolverine Model 9.1 heaters, one on either side of the driveshaft tunnel. See Wolverine Engine Oil Heaters - Products
Having said all that, there should be no problem at all starting a well maintained FT404 in the weather we've been having lately. You should consider verifying that all your glow plugs are actually heating properly.
//greg//
   / block heating on Foton 404 #3
Just about every vehicle in Canada will have a frost plug block heater installed before it's sold new. There is very little trouble with them. The biggest problem may be driving away without unplugging them. :D
Probably the original frost plugs will give more trouble than the insert block heaters.
The lower Radiator hose heaters also work well.
Did you have a tarp over the tractor?:D
Hello,
No i did not have a tarp over it.........i was afraid it may catch on fire. (plus i had to elevate the heater to get it close enough to engine)
If it does have a freeze plug where would it be and what may it look like on this type tractor? I read that it would be near bottom and middle of block.
Oil pan heater is that the magnetic one? doesn't that burn oil where it sits?
what does a "insert heater block heater" do or look like?
guys, i am sorry for all of the questions, i am just a newbie trying to learn my way around a tractor.
   / block heating on Foton 404 #5
Besides the fact that it's typically a helluva lot colder up there than it is down here in Kentucky, the vehicles you're talking about are almost certainly on-road cars and trucks with gasoline engines. We're talking about off-road diesel tractors here. More to the point however, it's the owner-installed aftermarket freeze plug heaters that scare me.
//greg//
   / block heating on Foton 404 #6
You didn't look at that website, didja......? No, they're not magnetic - Wolverines are permanently affixed to the oil pan with adhesive and silicone sealant. When properly installed, they become part of the tractor. And when properly sized to the sump capacity, they won't heat the oil above 125F. Hence, no coking.
The reason most on-road drivers like coolant heaters is cuz it helps heat the interior of the vehicle faster. Creature comfort. What they don't realize, is that they're still starting their engine with cold thick oil. My old Mercedes for example, it's got a factory block heater. When I switch on the key, I see 40C on the temp gauge already. But when the engine starts, it takes a long time for the oil pressure to build. The pump is trying to suck cold thick sludge up from the oil pan and push it through the oil passages. My tractors on the other hand, start developing oil pressure before they even start. And because of the heat rising off the oil pan when idle, the temp gauge comes up comparatively quick as well.
I prefer to start a cold diesel with warm thin oil. And when the oil is warm, heat rises off it to warm the block and the water jackets. Neither of my tractors has either a cab or a heater, so I could care less how long it takes the coolant to warm up. I prefer the thin oil
//greg//
   / block heating on Foton 404 #7
The block heater/inline hose heater heats the entire block which does heat the oil. :D
Had one truck with a block heater in each bank. That could melt the snow off the hood and underneath the engine.:D
Hey, don't we do this every year?
   / block heating on Foton 404 #8
I have a lower radiator hose heater, the kind you take out 2" of hose and slip in. Works great. We see temps as low as -20 each winter and I have never had it not start. Plug it in and 1 hour later the block is warm to the touch.
Chris
   / block heating on Foton 404 #10
Seems like it -- I have a water heater on my 284 -- I might consider magnetic job to heat the hydro oil but not much else. The block heaters that fit in the frost plugs are much better than they used to be but if you are unsure, buy a bottom rad hose heater. In this climate in winter, diesels need that warming feeling -- on road or off road:rolleyes: -- gas will usually start.
2015 Ford Escape AWD SUV (A50324)
2015 Ford Escape...
2019 Cadillac XT5 SUV (A50324)
2019 Cadillac XT5...
2013 Ford F-450 Altec AT200A 30FT Bucket Truck (A50323)
2013 Ford F-450...
Land Honor 3 pt Disk (A50514)
Land Honor 3 pt...
2017 Caterpillar 326FL Hydraulic Excavator (A50322)
2017 Caterpillar...
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
