winterize the kubota
   / winterize the kubota #11
+1 on the block heater. Well worth it.
   / winterize the kubota #12
Here in drought stricken Central Texas.. I have done everything as folks up north..except a fuel additvie - Should I? Texas winters are light by any standard...but I would like to know what any Texas - Central and South owners "winterize".
Thanks
   / winterize the kubota #13
Back when I parked my BX in an unheated garage, I'd plug in the block heater for about an hour before starting it. When I did this, the temp gauge would already be half way to operating temp when it was started!!
   / winterize the kubota #14
My dealer puts block heaters in everything before it goes out the door. SOP up here in the north. Why wouldn't you? It's just got be easier on everything. Frankly, I wish I had put one in my truck years ago.
   / winterize the kubota #15
I've never treated my diesel fuel but make sure you don't use summer bought diesel in the cold, cold winter. The tractor suffers from total loss of power( but will keep running). I find the block heater makes for easy starts and a short wait for the engine to reach operating temperature.
   / winterize the kubota #16
This is my first winter with the kubota
I live in western Pennsylvania
I probably will only use the machine to move snow during the winter months. We don't get tons of snow so I probably won't have a use for the machine every week.
I keep it parked under a roof, unheated.
What should I do to winterize the machine?
Does any one change any fluids before or after winter, not concerning the hour meter recommendations.
I'd recommend putting a float charger on the battery, and dump a double-dose of Powerservice in the white can in your tank. That's it.
I keep my tractor in a tent-garage. It sits all winter doing nothing. I fill the tank to minimize condensation, put PS in the fuel, and that's it. Always starts right up in the spring - which is when you should change the engine oil. The only thing I am going to do different this year is I'm going to start keeping the battery on a float charger (don't use a "trickle" charger).
JayC
   / winterize the kubota #17
Thanks,
Rich
If your machine is fairly new and you bought it from your northern area, then just add some PS to your fuel.
Otherwise just check your battery,connectors, coolant ratio and oil weight....those premium diesels will crank up to -30 no prob with just the plugs.
If you have access to power / block heater you are ready for the next ice age.
   / winterize the kubota #18
So do think it's better to top off the fuel tank or wait till spring?
I always assumed topping off was best but then after reading some unrelated posts that diesel fuel can start to have stuff grow in it etc. I wonder if it's best to just put fresh fuel in the spring and run it down as low as you can before you store it for winter.
   / winterize the kubota #19
Thanks
I talked to three farmers around me, and all of them said they do not use the fuel treatment. All of them said they HAVE had fuel gell up on them though. After reading all these posts, I bought some PS in the white bottle and added it to my fuel. I would rather have it and not need it than need it and not have it.
   / winterize the kubota #20
Thanks for all of the advice, this is a big help. I'll do the fuel additive, the radiator has antifreeze in it.
BXRICK, i'll take your advice that the block heater is a good idea, but probably not necessary. I'll see how the first winter goes. Anyway, is a block heater something that I can install myself or is it a dealer job?
The block heater is an easy job assuming you have the right size allen key, 17mm I think. Its large! if you can drain your coolant, and have the allen key a cheater bar, and 45 minutes, then you can install the block heater... Good luck.
Makes a world of difference in the winter!!!
Yup, 17 mm and a good bar. Makes things eaiser when it's -20.
You can find some photos on how to install a block heater on a BX.
KUHN GMD-310-HD LOT IDENTIFIER 38 (A53084)
KUHN GMD-310-HD...
JOHN DEERE TS LOT IDENTIFIER 138 (A53084)
JOHN DEERE TS LOT...
2025 New/Unused 72in Wolverine Grapple Bucket (A51573)
2025 New/Unused...
2023 FORD TRANSIT VAN (A52576)
2023 FORD TRANSIT...
PALLET OF 6' X 12' SITE FENCE (A51248)
PALLET OF 6' X 12'...
2013 MACK GRANITE (A52472)
2013 MACK GRANITE...
