Need help...TZ25da Hydraulic fluid question...
   / Need help...TZ25da Hydraulic fluid question... #1
wny770
Gold Member
WNY
Lots of old iron
I just changed the O-ring and wiper on the three point lift cylinder on my TZ25DA. What a pain...(I have a cab). I want to change the hydraulic fluid and filters now... It also runs the hydro. Without buying NH fluid, what can I use??? Is there a synthetic I could use? At 50 hours I switched the engine to Rotella synthetic and am glad I did. thanks for all replies.
   / Need help...TZ25da Hydraulic fluid question... #2
When I did my 300 hr service on my 1620 it called for a fluid change on the hydro trans/hydraulics. I read a lot of posts to read what people did and chose to put the Tractor Supply (TSC) Universal Hydro fluid in as it meets the ford/new holland specifications. However I noticed a lot of low speed groaning while the fluid was warming up. And when it was cold out (20 degrees F and below) the hydro pedal was sluggish to return and there was more low speed groaning/whining. It just didn't seem right and I did not want to have to worry about the HST trans, so I switched back to the New Holland fluid and the issue went away. $70 is for a 5 gallon pail of the New Holland fluid seemed a lot cheaper then risking my trans. But, who knows.....
my 2 cents and experience.
I thought it would be more expensive that that. I am going to put the NH oil in. Thanks for the reply.
   / Need help...TZ25da Hydraulic fluid question... #4
NH oil was $52 for 5 gallons a couple of years ago at my local dealership.
I bought the fluid. $80 for 5 gallons. Not too bad. BUT...what made me cry was that little trans filter....$32.....and no, it doesn't cross to a Napa number:eek:
2024 Bison Tek Skid Loader BT360 (A52384)
2024 Bison Tek...
LATE MODEL JOHN DEERE EQUIPMENT AUCTION (A53084)
LATE MODEL JOHN...
1265 (A50490)
1265 (A50490)
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
2009 Chevrolet Trail Blazer SUV (A51694)
2009 Chevrolet...
2012 FORD 4 DOOR TAURUS (A53426)
2012 FORD 4 DOOR...
