JD 260 disc mower hyd. cyl. seal kit
   / JD 260 disc mower hyd. cyl. seal kit #1
Kfbeal
Gold Member
South Texas
2005 JD 5103
Do any of you know if the seal kit for the hyd. cyl. on a JD 260 disc mower would be found in part stores rather than a JD dealer?
On the JD parts website it shows $93.50 but I don't need all the seals. I just blew out the insert in the metal bushing. It's like an internal seal.
BTW, it's a single action cylinder.
Any suggestions?
   / JD 260 disc mower hyd. cyl. seal kit #2
I would suggest telling them to order only the seal you need.
   / JD 260 disc mower hyd. cyl. seal kit #3
Take the cylinder to a local hydraulics's shop...
   / JD 260 disc mower hyd. cyl. seal kit #5
Unfortunately they are usually sold a "kits" for a complete rebuild.
JD, gotta love them guys. Take your cylinder to a shop like Kenny says. Most shops will rebuild that cylinder and give you a warranty for less than JD charges for the parts. Best part is JD gets their seals from Hercules, same place as us shops. Comes in the same exact package.
Andy
I think before I could order just pieces, but not sure. I may have gotten the entire kit which probably should be done while I'm in there, I'm just cheap. I'm sure it's a kit, and not pieced out.
Any hints on how to get the plastic inside of the metal busing? Before I had to squeeze it like a marshmallow and allow it to expand on the inside. It's a hard plastic so it wasn't easy to say the least without experience.
   / JD 260 disc mower hyd. cyl. seal kit #7
Is it like what's pictured in THIS thread? Then follow my advice to boils it...there is also a link to Hercules where you can order individual seals.
Yea, sure is. I be d@mned, I never thought about boiling it. Talk about a PITA to get in without doing that. Wonder how I would find the seal # at Hercules from my cylinder. Do you think JD would tell me by chance what seal #'s I need?
   / JD 260 disc mower hyd. cyl. seal kit #9
The boiling trick works nice! Very easy to fold it into the C shape and pop it in...
I doubt anybody at the dealer knows what the part number is other than the JD one...you will need to measure your old seals to order from Hercules.
2018 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A52576)
2018 FREIGHTLINER...
2012 SULLIVAN PALATEK AIR COMPRESSOR (A52576)
2012 SULLIVAN...
2019 JOHN DEERE 5090M LOT NUMBER 91 (A53084)
2019 JOHN DEERE...
PENDING SELLER CONFIRMATIONS (A53426)
PENDING SELLER...
28013 (A50322)
28013 (A50322)
2006 International 4300 Water Tanker Truck (A52384)
2006 International...
