15 inch type B pulley with 1 1/4inch hole
   / 15 inch type B pulley with 1 1/4inch hole #1
Deck III
Good morning everyone,
I am looking for a stamped steel 15inch type B pulley with a 1 1/4inch hole and key stock knockout. I was wondering if anyone could point me in the right direction?
   / 15 inch type B pulley with 1 1/4inch hole #3
Did you try your local industrial belt/bearing supply?
Check acklands.
This wont be an inexpensive thing.
   / 15 inch type B pulley with 1 1/4inch hole #4
I've seen this approximate size at TSC and at JD and NH dealer stores. They are typically used on haybine and combine reel drives. They usually come as 2 piece sections with a main wheel and a separate hub for different shaft sizes and types of shaft locking. They are NOT typically used for moderate to high speed applications, if that's your purpose. Hope that gets you close.
48" Skid Steer Pallet Forks  (A52384)
48" Skid Steer...
2025 25ft. 800Amp Extra HD Booster Cables (A51692)
2025 25ft. 800Amp...
2019 FORD TARNSIT CONECT CARGO VAN (A52577)
2019 FORD TARNSIT...
2020 FREIGHTLINER CASCADIA 126 TANDEM AXLE SLEEPER TRUCK (A52141)
2020 FREIGHTLINER...
FORD 540 TRACTOR (A51247)
FORD 540 TRACTOR...
2017 Ford 550 XL, Cab and Chassis, Crew Cab (A52384)
2017 Ford 550 XL...
