PTO Shaft for a Kubota FL1000 Tiller
   / PTO Shaft for a Kubota FL1000 Tiller #1
zman007007
Gray Court,S.C.
B7100HST-E
I posted this a few months ago and I am still looking for one. I need the upper part of the PTO shaft for a Kubota FL1000 tiller. I just need the upper part that attaches to the tractor, 1 3/8 with 6 splines, with the universal joint and then it has the female coupler that slides over the bottom male part. The bottom male part has the slip clutch on it. I have it. I have tried 3 different dealers around here and they tell me I have to buy a complete shaft which is about $400.00. I have also checked TSC, and 2 other souces recommended with no luck. I have the indivual part numbers if needed. Just thought I would try again. Thanks for any help. zman
   / PTO Shaft for a Kubota FL1000 Tiller #2
Do you have anyway to post a picture of the type of shaft you are looking for? I have square ones, rectangle ones, and even a triangle shaped one on my equipment. There are probably other shapes as well and many different sizes. If you could give us some more details about that particular shaft, I think it would help the search. There are also places here locally that repair drive shafts. If you could find a place in your area that does that type of work, they would have a lot of resources for finding parts.
:)Yes I will try to post some pics of the parts I do have later today. thanks zman
As you can see from the pics, I actually have the female part that attaches to the tiller, not the male part. I need the male part that comes from the tractor. The i.d. of the female shaft is a little over a inch. It has 10 small spline grooves and one that is about3/8 of an inch wide. Any help is appreciated. zman
   / PTO Shaft for a Kubota FL1000 Tiller #5
I spent some time at my local dealer today picking their brains regarding your pto shaft. I even emailed them the picture. They have been in business for over 50 years and they have not seen that particular shaft before. The parts guy tells me that for the FL1000 tiller there was two different pto assemblies. The newer style he can order the male part, but the older style, which looks to be the splined version like yours, he cannot any longer order just the male part. It subs to the entire pto shaft like you have already found out. They did suggest that a local machine shop may be able to turn you out a matching shaft if you take them the female part. You would still need to order the knuckles and joints for the end of the shaft. The problem may be that by the time you get all that done, you are still looking at a pretty hefty bill.
You could also take the female half to a drive shaft repair shop, have them cut off the existing splined shaft and have them weld a more conventional shaft onto it. (ie: square/rectangle). Then get a corresponding male counter part and you're set to go.
Sorry I don't have better news for you.
:DI sure appreciate all your effort and trouble you went to, couple of achers. I believe I will have to carry it to a machine shop, or drive shaft shop.thanks again zman
   / PTO Shaft for a Kubota FL1000 Tiller #7
G'day zman check out the bare co site they have a large range of pto gear and uni joints by size you may be able to find something there that you can make up
Jon
:cool:thanks for the info Jon, I just checked the site and I did get a few more ideas how to do it. I"m beginning to think this tiller ought to be in the Smithsonian. lol zman
:cool:thanks to all for trying to help. I finally found one, and it was only about 60 miles from me. I bought it from an indivual who had 2 and he only needed one. thanks again zman
   / PTO Shaft for a Kubota FL1000 Tiller #10
Just in case anybody is watching this thread, I need this same part for a Kubota FL850 tiller - the front half of the pto shaft. The Kubota part numbers may be
70710-61310
70710-61330
70710-61340
70710-61360, and
70415-52250
Any info would be greatly appreciated. Thanks in advance.
2003 International 4300 Flatbed Truck w/ Liftgate - Inoperable - 7.6L DT466 Diesel Engine (A55218)
2003 International...
2013 VOLVO VNL64T TANDEM AXLE MID ROOF SLEEPER (A54313)
2013 VOLVO VNL64T...
2020 John Deere XUV 835M Gator 4x4 Utility Cart (A51691)
2020 John Deere...
2025 Swict 66in Bucket Skid Steer Attachment (A53421)
2025 Swict 66in...
2004 Ford F-250 4x4 Service Truck with Liftgate (A53422)
2004 Ford F-250...
