Leaf cleanup- Saw this used
   / Leaf cleanup- Saw this used #1
asylum575
Rockland Cty, NY(sou. NY)
Kubota BX24
I was watching a bunch of guys doing a lawn cleanup and noticed a new gizmo. There were two guys blowing leaves with 8-11hp blowers. The third guy was on a walkbehind with velky. He had a plywood board with a rubber door sweep on the bottom. It raised and lowered with the deck. He used it like a plow and pushed large quantities of leaves around.
Has anyone come up with something like this for a FEL.?
   / Leaf cleanup- Saw this used #3
That is a neat idea. This morning I was pushing 15 cu yds of leaves, and I only have a 1/2 acre front lawn, using my fel. I only managed to plow the grass on one pass.
Since I have a toothbar, it might be a difficult design.
It was similar to the first one. It had a metal frame and plywood boards. The bottom had that rubber doorsweep material. Worked great with the leaves that were blown onto the road. Pushed them into a nice neat pile.
   / Leaf cleanup- Saw this used #5
maybe a bit overkill, but why not i say?
   / Leaf cleanup- Saw this used #6
I used to use my snowplow or my FEL bucket to push the leaves into the woods after I windrowed them with my blower. Now, I just mow them up and use my lawn sweeper to brush up the chopped up leaves. Works great.
   / Leaf cleanup- Saw this used #7
LandscaperPRO sells an all metal one (leaf plow) with rake like tines at the bottom , for walk behinds, they start at $495 plus a $119 mounting bar landscaperpro.com
   / Leaf cleanup- Saw this used #8
Do you mean something like this? I built this to use on my Branson FEL for pine needles. It works great for branch and bush trimming.
I made this out of stuff that I had laying around.
   / Leaf cleanup- Saw this used #9
The company I mentioned earlier is in Spring Valley NY on Chesnut Ridge road
You could adapt it to your loader bucket easily
   / Leaf cleanup- Saw this used #10
My leaf dumpster is as big as all out doors in fact it is the out doors as I just leaf them lay .
This makes the forty third fall I've done it this way.
Couldn't be any quicker and easier.
1980 PULLMAN DRYVAN (A58214)
1980 PULLMAN...
2022 Ford Escape S AWD SUV (A55853)
2022 Ford Escape S...
1969 Lincoln Continental Mark III (A56859)
1969 Lincoln...
INVERSION DEVICE (A58374)
INVERSION DEVICE...
2019 Ford F-250 4x4 Ext. Cab Knapheide Service Truck (A55973)
2019 Ford F-250...
New/Unused 14ft Bi-Parting Iron Gate (Elk Design) (A57453)
New/Unused 14ft...
