Jubille New to me
   / Jubille New to me #1
tessiers
Central Maine
05' JD 790 - 53' Ford NAA - 70' Massey Fergusen 135 diesel - 67' John Deere 3020 deisel - 77' John Deere 2130 - 1950 John Deere MC
I just picked up a 53 jubilee for next to nothing. I have known the fellow who owns it for a long time and his father bought it new. It was completely gone through about 12 years ago including 4 new tires and was only used for bush hogging since. Here's the catch, it hasn't been started in 6 years. It was stored under cover but not touched in all that time. I am hauling it home tuesday and I would like any advice on what I should do before running it. I intend to change all the fluids and filters, clean the fuel tank and lines, anything else I should do or look for?
   / Jubille New to me #2
Hey Tessiers, i would go to SSB Tractor Discussion, they have a section on that site for Ford tractors...they could really give you some good advise on those specific tractors...........I personally would change the plugs, wires, pionts, condenser, and cap also, but check that site out and let me know how it turns out...Don
   / Jubille New to me #3
6ys ain't too bad.. I just pulle dmy NAA out of the barn after 7.
Pull the plugs and put some marvel mystery oil in each cyl.. or regular atf oil.. whatever is your choice.. roll the engine over by hand each day and add more oil. this lubes the rings.. etc.
replace plugs with somehting like a champion h12 or autolite 437.. clean or repalce points. gap points and plugs at .025
add some fresh gas and a battery and see what you get.
post back
soundguy
   / Jubille New to me #4
I used to own a 53 Jubilee and it was a great tractor...I sure wish I had never sold it. Mine did not have a fuel filter so I would suggest - unless they added one and since it has been sitting for 6 years - I would add a fuel filter or new fuel filter to the fuel line and be sure to check your fan belt. The main thing will be to be sure as another posted that the engine is lubricated before just starting it up after sitting all that time and to be sure all of the sediment is out of the gas tank and the carb will need to be cleaned real good.
   / Jubille New to me
Put the marvels to it already, took the fuel line off and it is clean as a whisle, he must have drained the gas. Battery was split down the side so it will have a new battery. I was told by our company mechanic to run a couple of gallons of mixed chainsaw gas through it for a little extra lube, he said it will smoke a little but it won't hurt it, what do you guys think.
   / Jubille New to me #6
I think his idea had merit. Years ago you used to be aboe to by a product called top oil, you just added it to the gas.
   / Jubille New to me #7
I'd run some marvel or atf thru the gas.. but no mixed oil.. it will foul the plugs out real fast.
soundguy
   / Jubille New to me #8
the fuel tap in the fank had a filter on it, up inside the tank.. in the fuel sediment bowl below the tank there was another filter, and at the fuel elbow inlet into the carb was yet another filter!!!
that's 3 oem filters!!!
I don't know how many fuel flow problems I've fixed for others by REMOVING the non oem automotive gas line filters they had installed.. most of those filters are used in systems with fuelpumps pushing 4psi or so.. the setup in this tractor is gravity feed.
soundguy
   / Jubille New to me #9
soundguy
That's a bunch of fuel filters, I can see where that would cause all kinds of problems. My Jubilee did not have even one fuel filter I could find when I got it. At one point it must have been used on a cotton farm since about every 25 hrs. it would stall to a stop and every time I had to dig a cotton like substance out of the carb...so I put a fuel filter on it and that fixed the problem..I should have taken the tank out and would have but the filter cured it and I would change the filter every fifty hours or so.
   / Jubille New to me #10
the point is. there should be multiple fuel filters already in line.. hard to believe all of them are missing?
soundguy
2002 Ford E-150 Passenger Van (A51692)
2002 Ford E-150...
1998 Jeep Cherokee Sport (A50123)
1998 Jeep Cherokee...
2015 Jeep Compass SUV (A50324)
2015 Jeep Compass...
2004 Wabash National 28ft Dry Van Trailer (A51692)
2004 Wabash...
2019 JOHN DEERE 310SL HL BACKHOE (A51406)
2019 JOHN DEERE...
2021 QUALITY CARGO, LLC QUALITY CARGO, LLC (A53843)
2021 QUALITY...
