Leaf cleanup- Saw this used
   / Leaf cleanup- Saw this used #1
asylum575
Rockland Cty, NY(sou. NY)
Kubota BX24
I was watching a bunch of guys doing a lawn cleanup and noticed a new gizmo. There were two guys blowing leaves with 8-11hp blowers. The third guy was on a walkbehind with velky. He had a plywood board with a rubber door sweep on the bottom. It raised and lowered with the deck. He used it like a plow and pushed large quantities of leaves around.
Has anyone come up with something like this for a FEL.?
   / Leaf cleanup- Saw this used #3
That is a neat idea. This morning I was pushing 15 cu yds of leaves, and I only have a 1/2 acre front lawn, using my fel. I only managed to plow the grass on one pass.
Since I have a toothbar, it might be a difficult design.
It was similar to the first one. It had a metal frame and plywood boards. The bottom had that rubber doorsweep material. Worked great with the leaves that were blown onto the road. Pushed them into a nice neat pile.
   / Leaf cleanup- Saw this used #5
maybe a bit overkill, but why not i say?
   / Leaf cleanup- Saw this used #6
I used to use my snowplow or my FEL bucket to push the leaves into the woods after I windrowed them with my blower. Now, I just mow them up and use my lawn sweeper to brush up the chopped up leaves. Works great.
   / Leaf cleanup- Saw this used #7
LandscaperPRO sells an all metal one (leaf plow) with rake like tines at the bottom , for walk behinds, they start at $495 plus a $119 mounting bar landscaperpro.com
   / Leaf cleanup- Saw this used #8
Do you mean something like this? I built this to use on my Branson FEL for pine needles. It works great for branch and bush trimming.
I made this out of stuff that I had laying around.
   / Leaf cleanup- Saw this used #9
The company I mentioned earlier is in Spring Valley NY on Chesnut Ridge road
You could adapt it to your loader bucket easily
   / Leaf cleanup- Saw this used #10
My leaf dumpster is as big as all out doors in fact it is the out doors as I just leaf them lay .
This makes the forty third fall I've done it this way.
Couldn't be any quicker and easier.
2025 JMR 40in Single Cylinder Brush Grapple Mini Skid Steer Attachment (A56857)
2025 JMR 40in...
8 sets of Jumper Cables (New/Unused) (A59225)
8 sets of Jumper...
NEW Wolverine Skid Steer Auger Drive And Bit (A59000)
NEW Wolverine Skid...
New/Unused CFG Industrial MX15RX Mini Excavator (A57453)
New/Unused CFG...
Magnum 4000 Series Hot Water Pressure Washer (A55272)
Magnum 4000 Series...
Pull Type Concrete Mixer (A57453)
Pull Type Concrete...
