greg_g
Super Member
- Joined
- Dec 18, 2003
- Messages
- 6,126
- Location
- Western Kentucky
- Tractor
- JD3720 Cab, 300X loader with 4-in-1 bucket
YesIs the crown nut the one on top of the ball joint?
Good grief. If it wasn't for bad luck, you wouldn't have any at all. That bottom cover is threaded, with a split pin to keep it from backing out. If you've somehow lost the pin AND the cover, then the ball socket and spring probably fell out too. Any chance you found and/or saved any of those pieces?Standing in front of the tractor, the insides of that ball joint are gone, and so's the bottom cap that holds everything in.
No, the zerk is on the pull-joint housing itself. Don't remember which is which, but the zerk on one side faces forward, the other faces back. If you only see a threaded hole, then you've lost the zerk as well.The grease nipples on the outside of the front wheel hubs lubricate????
//greg//
