Anyone know about this plow?
   / Anyone know about this plow? #1
warhammer
Gold Member
Central Texas
Kioti DK45SE HST
This plow is being sold near where I live. The owner says it is a Ford IO-156 2bottom plow.
These good plows? Will my Kioti 45HP HST pull this thing ok? I would be using it on a small farm that has been rowcropped yearly for decades.
Warhammer
   / Anyone know about this plow? #2
If you could make the picture a bit bigger it may help to identify it.
Your tractor should have no trouble pulling a two bottom plow. Mine is 35 HP and does just fine.
Mark
   / Anyone know about this plow? #3
I agree it is a Ford plow, as I have one just like it. I bought mine for $475 (without the coulters) and pulled it with Kubota M 6800. You would have no problem pulling it. However, I would not buy another, as mine is for sale. It did fine until I hung a hidden rock and this snapped four of the frame bolts and bent a share. I repaired it with new bolts and new shares, and again used it. It plowed soft soil great, until I encountered another buried rock. This time I broke more bolts and bent the diagonal frame member badly. Maybe my tractor is just too heavy and powerful, but I was not going fast and was trying to be careful. I have spent almost $150 dollars on parts (two 17" grade 8 bolts, a dozen shorter bolts, and costs of fabricating a new frame member, and shares) and don't plan to use it again. Maybe in softer soil, it would be fine, but if it were my choice, I would buy a plow with trip protection, either shear pins or springs, to be safe. I since bought and restored another Ford plow (a 3 bottom with shear pins) and it works great, although I frequently trip the bottoms but at least that's a cheap, quick fix. How much is the asking price?
Oh, I realize soil conditions would ultimately determine whether it would hold up, but I broke mine twice in less than 5 hours of use. Be safe, look for another, more modern design with the bottoms protected by trip mechanisms.
   / Anyone know about this plow? #4
I pulled a very similar plow with a Ford NAA (30 HP PTO) so I would think your tractor would handle it fine. My Ford had Ag tires which can make a big difference.
I think that was your problem. I hit rocks and roots with my Ford and it stalled the tractor rather than breaking the plow.
New Kivel 4200 lb. Skidloader Forks (A50774)
New Kivel 4200 lb...
2003 International 4300 Flatbed Truck w/ Liftgate - Inoperable - 7.6L DT466 Diesel Engine (A52128)
2003 International...
Neckover GL24-2-7K Gooseneck Trailer  24ft Deck, Dual 7K Axles, 14K GVWR (A52128)
Neckover GL24-2-7K...
2020 KENWORTH T880 ROLL OFF (A51222)
2020 KENWORTH T880...
2014 UTILITY DRY VAN TRAILER (A51222)
2014 UTILITY DRY...
2017 Ford Explorer AWD SUV (A50324)
2017 Ford Explorer...
