Desperately looking for an uncommon part
   / Desperately looking for an uncommon part #1
arthr31
new england
3 Yanmars
hi all yanmar fans,
Long time, no post.
My 1601d was still running good up until about two weeks ago when I broke it (oops). I was changing the fuel filter assembly and where it attaches to the block/head (can't remember which) and it broke a cover in two. Now I have a nice hole to the engine that I don't want!
I've attached a couple of pics of the area and the part I'm looking for. Does anyone have this part? Know where I can get it? Hoye doesn't have one and I've tried getting one fabricated but am running out of options.. The tractor has been down for awhile now and needs to be working!!!
Thanks for any help / ideas or leads you might have for this part.
(in the 2nd picture you can see the fuel filter assembly at the bottom of the photo, the hole is where the "cover" goes and the assembly connects to the eyelet on that cover)
   / Desperately looking for an uncommon part #2
Build a replacement cover.
Piece of scrap 1/4 steel, make the upper 'ear' slightly taller for nut on back.
Good idea, want to try and find a replacement first. If not that, I'll find someone who can cut some metal like that and build one. Thanks!
   / Desperately looking for an uncommon part #5
It doesn't appear to be cast, if not, I would simply clean it up and mig weld it then grind down the welds. Looks like a quick and simple fix from the pics.
   / Desperately looking for an uncommon part #6
I think it's cast aluminum, if so an experienced TIG welder can fix it.
   / Desperately looking for an uncommon part #7
Yeah, I think you might be right. Looking at it again, the top broken edge does appear to be cast. Like you said, it could be TIG'ed and be good as new for much less than an OEM (if available)part. Doesn't appear to be a difficult fabrication as others mentioned for that matter.
   / Desperately looking for an uncommon part #8
Assuming you have called the usual Yanmar parts people, next I would take that to a local machine shop and ask them to duplicate it as a steel plate with a nut welded on for the filter to attach to. (I assume that is what the upper hole does).
I think usually it is best to keep these 100% authentic. But since this broke, it is one case where making a better replica part is justified.
And I think buying local will save a lot of frustration.
   / Desperately looking for an uncommon part #9
While you are searching for a replacement part, patch the hole with any kind of sheet metal and gasket cement, wire up the filter bowl and get on with your life.
   / Desperately looking for an uncommon part #10
Why is there a whole into the engine that looks like it exposes the crank or some other internal part? This filter just bolts to the block not like it has a pushrod that rides on the crank? Why would yanmar not jsut tap 2 holes into the block to mount the housing, are these universol blocks where some have a part that goes through to the inside there like an old mechanical fuel pump on a truck would?
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59904)
2017 FREIGHTLINER...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
Freightliner Tender Truck - Adams Tender (A56438)
Freightliner...
2018 Toro Groundsmaster 7200 72in Zero Turn Commercial Mower (A59228)
2018 Toro...
Kubota ZG222 (A60462)
Rotary SPOA9-200 Automotive Lift (A56857)
Rotary SPOA9-200...
