6sunset6
- Joined
- May 6, 2007
- Messages
- 1,057
- Location
- SE NY
- Tractor
- NH TC34DA 34HP HST, 2 rear remotes, front diverter, loaded R4's
I have a TC34DA with a 240TL FEL . I had forks on it 132#. I was lifting a banded load of steel roof panels . 877# Total load 1009#.
I could lift it about 5 ft off the ground, no higher. This was a bummer as I could not get it high enough to set on the staging for passing up to the roof. We got the panels up one at a time by hand. My question is why could I lift 5ft and no higher. I did check the oil level and it was at the low mark with the forks 4ft up. Low was probably due to adding snow blower cylinders . I don't think that was the problem. Anyone have a clue?
