Nailing Tin Roof (Dumb Question)
   / Nailing Tin Roof (Dumb Question) #41
Pre-drilling is an excellent idea... wish I had thought of that the last time I installed a metal roof... Good thinking!
   / Nailing Tin Roof (Dumb Question) #42
Pre drilling makes the lines of screws all line up real purty. I did it on a building right by the house that everyone can see and it really is nice and tidy. On other sheds I don't really care so much so I've either done it ad hoc or used a string line. NOTE: You have to make sure the holes will line up with your roof strapping though. If the building is old and not straight it may not work.
Just seemed like a waste of time to me, string line is easier. Also like you said if something doesn't line up, now your stuck with holly roof panels.
   / Nailing Tin Roof (Dumb Question) #43
If you pre-drill, make sure that your drill bit is smaller than the screws. If it is larger there is a greater possibility that it will leak.
When you screw into the metal, the screw pulls the metal up around it making a sort of levee around the hole. Then even if you remove the screw the raised part helps keep water from entering the hole.
A nail does the opposite. When you nail metal it bends the metal down around the hole so that when the nail works it way loose, water is channeled down the hole.
   / Nailing Tin Roof (Dumb Question) #44
I usually lay out holes with drywall square and a marker just dotting surface and use self drilling screws
tom
Very good point.
   / Nailing Tin Roof (Dumb Question) #46
without reading all these posts, i looked at my roof and saw that when I installed it I screwed into the flat part and then screwed into the ridges where the steal overlapped. I thought I had only screwed into the ridges like I posted a few days ago.
I also think that predrilling is a waste of time. If you are concerned about screwing in a straight line then just use a straight board to line up the screws.
2017 Ford F-550 Service Truck (A59230)
2017 Ford F-550...
John Deere 5055E (A53317)
John Deere 5055E...
2011 INTERNATIONAL DURASTAR 26FT NON CDL BOX TRUCK (A59904)
2011 INTERNATIONAL...
RAKE ATTACHMENT FOR MINI EXCAVATOR (A58214)
RAKE ATTACHMENT...
2019 MACK GRANITE (A58214)
2019 MACK GRANITE...
Great Dane Van Trailer 1989 (A56438)
Great Dane Van...
