2 Cycle Will Not Rev Up
   / 2 Cycle Will Not Rev Up #1
davey4000
Roxboro, NC
JD 4320, NH TC29D
I have a Stihl model HS 80 hedge trimmer that will not rev up. The last time I used it about a month ago it ran fine. It cranks very easy, but when I pull the throttle it dies before it even gets up to 1/3 speed. I have changed the plug, cleaned the air filter and changed the fuel pick-up filter. It has new fuel in it. Since it ran fine the last time I used it I have not messed with the carberator adjustments. Any suggestions?
   / 2 Cycle Will Not Rev Up #2
Have you taken the carb apart and cleaned the jets?
   / 2 Cycle Will Not Rev Up #3
Also make sure the spark arrestor on the exhaust isnt plugged up with black soot and carbon. Some manufactures put small screens on their mufflers that gum up and make the unit do that....
Craig
   / 2 Cycle Will Not Rev Up #5
So far, every time I've had that kind of problem with a 2 cycle engine, it's either been the exhaust plugged up, as already mentioned, or a simple carb adjustment. I've been lucky enough to not even have to take a carb apart.
   / 2 Cycle Will Not Rev Up #6
i have to agree with the carb cleaning and or adjustment, and the plugged exhaust.............good luck.....Don
   / 2 Cycle Will Not Rev Up #7
I would clean the carb, just went trough this with a blower. Darn ethanol.
Thanks for the advice. When cleaning the carb does it require taking it off or is there something that can be sprayed in it to do the job? I removed the spark arrestor and cleaned it. It was not very gummed up at all. It did not help the situation. It still will not rev up and stay running. The engine idles perfectly however. Now I'll out of town on business all week. I'll get back on it this weekend.
   / 2 Cycle Will Not Rev Up #9
I had a similar problem with a Stihl chainsaw. I found the problem was the fuel line ahd gone bad due to ethanol just ate the rubber. One juel lint about 5 inches long $14.
   / 2 Cycle Will Not Rev Up #10
That's what I thought until I reread his first post where he said he had changed the fuel filter. If he did that and the pickup hose was deteriorated, surely he would have noticed. So I'm no longer thinking that could be the problem.
If your Stihl engine is like my chainsaw, there are two adjustments. One is just the idle speed adjustment. The other is the fuel adjustment. To set it properly, carefully rotate it clockwise to the the stop and then rotate exactly one turn CCW. Start the engine and adjust more CCW until the engine responds well with no stalling. Make very small adjustments. It doesn't take much to make a big difference with this screw. If it is adjusted properly, the engine will accelerate very well and have plenty of power to boot.
flooring (A53424)
flooring (A53424)
2019 Chevrolet Silverado 2500HD Crew Cab Liftmoore 2700AR 1 Ton Crane Service Truck (A52377)
2019 Chevrolet...
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A53422)
2013 Ford F-150...
CATERPILLAR 631E SERIES II MOTOR SCRAPER (A52706)
CATERPILLAR 631E...
2010 FORD F350 SUPER DUTY SERVICE TRUCK (A54607)
2010 FORD F350...
DOOSAN G25KW GENERATOR (A53843)
DOOSAN G25KW...
