rider9403
Member
I went from a 30hp to a 44hp. There are things the 44hp tractor will do that would take the 30hp tractor a lot longer to do. But there are things the 30hp tractor will do that the 44hp tractor can not do. If you buy one tractor in the bigger size you are going to find a gap that can only be filled with a smaller unit. So down the road you'll be back on here asking about SCUT or small CUT sized tractors.
I guess there's no size that's perfect. But for a small acreage I think almost everyone will tell you the smaller CUT, 30hp range, is your best fit.
My 44hp tractor does not have a cab. 90% of the work I do with it could not be done with a cab.
My 23hp tractor does not have a cab either. 90% of the work I do with it could be done with a cab.
But in the end, to complete your projects, you are gonna have to get out of the cab because of the limits the size of a 45hp tractor with cab puts on you.![]()
I'm looking to get a 40 to 45hp tractor with a cab. I'm in upstate NY in the snow belt area. I have a couple of long drive ways to remove snow from and in the few hundred acres land to manage, mostly woods. What kind of work could not be done with your 44hp tractor if it had a cab on it?
