California
Super Star Member
- Joined
- Jan 22, 2004
- Messages
- 15,003
- Location
- An hour north of San Francisco
- Tractor
- Yanmar YM240 Yanmar YM186D
I am gradually cleaning up some minor neglected stuff on the YM186D I bought last summer.
The tach cable sounded noisy when I bought it, and the tach needle was jumpy. The cable core looked well oiled so I rubbed it down with a paraffin block. That quieted it for a while. Now there is jarring whine for a moment when I start. I thought the starter might be failing to disengage but then I noticed the tach needle is jumpy again.
I found that the noise is sensitive to where the tach cable is routed. If I could tie it down in just the right location it would stay quiet. But moving it causes the screech and jumpy tach. It seems the racket comes back whenever the cable pushes sideways (or inward?) where it enters the tach. The screech sounds like stripped gears in the tach, and the needle stays past maximum rpm.
Has anyone seen this? Was it the cable, or the tachometer?
Replacing the tachometer cable looks easy but doing the tach would mean removing the steering wheel and dashboard, probably an afternoon project.
