Open center log splitter valve or closed center valve?
   / Open center log splitter valve or closed center valve? #1
ALF_HMC
Just south of Knoxville TN
Montana 3440 HST
I have a Montana 3440 hst and just bought the speeco log splitter. Does anyone know if I need to use the conversion kit that comes with it?The conversion kit changes it from a open center valve to a closed center valve. For whatever purpose?
   / Open center log splitter valve or closed center valve? #2
Put a gage in the pump circuit and see if you have constant high pressure. An OC system should read no pressure to very little pressure. .
I'm not a verry mechanical person...how would I do this?
   / Open center log splitter valve or closed center valve? #4
No, Your machine is OC.
O.K. thanks alot for the information and for everyones input.
I have installed the speeco log splitter(oc) and it seems to run good.the legs and frame holding the log splitter needs some beefing up though.I used 2 5ft 4000lb preasure hoses and luckily 2 general pioneer disconnects from tractor supply.
2019 Doosan LCV6W Towable LED Light Tower (A51691)
2019 Doosan LCV6W...
2021 JOHN DEERE HX14 LOT NUMBER 14 (A53084)
2021 JOHN DEERE...
FORD 1900 TRACTOR (A51247)
FORD 1900 TRACTOR...
2012 PETERBILT 587 SLEEPER (A54313)
2012 PETERBILT 587...
2008 KZ Sportsman Police Bunk 5th Wheel Tri-Axle Travel Trailer (A51694)
2008 KZ Sportsman...
KSI Conveyor (A55301)
