Egon
Epic Contributor
Are you gonna add a sauna to it?
Are you gonna add a sauna to it?![]()
Wow, that's some "outhouse" - geez, the ones I've "met" in my travels are pretty shabby compared to this Taj Mahal!!
After getting most of the wood done, it was on to tile. I put this step off as long as I could, because I had never done tile, and I was rather intimidated by it. It went well, and turned out as well as I had hoped. My boy had the idea to do the cut tiles along the front top on the tub, and it worked out good. Next, I installed the propane heater. It is a 300 sq. ft. unit, so it heats up my 65 sq.ft. area quite quickly. As for now, I am at a standstill as winter has arrived up there. I will post more photos as I make progress, but I am sure progress will be slow until next spring when I can get water to the building and install the water heater. What do y'all think?
If you're going to do it, you might as well do it to the extreme!!
From some of the pictures, it looks like a pretty incredible view that you have from there. Did you put in a window to take advantage of that view?
Eddie
The is actually a perfect application for a Sun-Mar composting toilet. Composting Toilets By Sun-Mar - The Environmental Solution I installed one on my farm years ago and it truly is easy to use , requires no plumbing and has absolutely no odor. My wife and I enjoy it so much that we decided to sell them.
Andy
Those look pretty slick. I'll have to read up on them when I get time.
