Why is "How many Kubotas do you have" closed
/ Why is "How many Kubotas do you have" closed #1
allenr
Gold Member
Barossa Valley, South Australia
Duetz DX3.70, Fendt 305LSA,260S & 205P,Kubota B6100E & 3 x B5100E & RTV900, Caterpillar 428C
Finally happened to have all my Kubotas tractors in the one place at one time, thought it was a good chance to add my RTV to the photo opportunity and add it to the above thread.
Alas, it's closed - why?
Anyway, here they are.
MVC-828F.JPG The two on the right are set up as air pruners for the vineyard.
MVC-822F.JPG The Cushman with the wheel missing is also Kubota powered.
MVC-824F.JPG The middle one has Ag rears (bigger dia) and ribbed front (smaller dia) than the other two with Turf tyres hence the different angle of the bonnet.
MVC-826F.JPG This is the most recent B5100 and came with the linkage bar but nothing much to stop it flipping over while towing, I added the "A" and a non adjustable top link. The "A" can be lifted out to allow the bar to be turned to a tow ball or the pin.
/ Why is "How many Kubotas do you have" closed #2
Because only people with more than one care and also don't want to hear about LB's three twins.:)
Thanks John. But seriously, why does a thread get closed?
/ Why is "How many Kubotas do you have" closed #4
Threads get closed for various reasons. I do not know the particulars as to why that thread was closed but it seems with LB's threads things get deleted by the moderators and closed so you don't really know what was said or what happened.
/ Why is "How many Kubotas do you have" closed #5
He (LB) may have had so many turning smiley faces and his other attention getting disk space hogs that it was deleted because of taking up to much server space.
/ Why is "How many Kubotas do you have" closed #6
I hope Les is OK, sorta weird not to see him chime in on this topic. :D
Why so many tractors Allen?
On the subject of moderators, Bird rocks. Easy to take it from somebody I respect.
Allen has a vineyard and uses them in it.
/ Why is "How many Kubotas do you have" closed #7
The moderators have a hard job and for the most part the moderators on TBN do a great job of following the rules. I have a ton of respect for these moderators and understand why they close certain threads and it isn't political. They have a set of guidelines to follow and they follow them well. But then again not everyone likes the way this board is run and that is why there are other boards out there but I have not found any other compact tractor boards better or anywhere near as good as TBN and NewAgTalk is the best for ag tractors.
Oops....done it again.
/ Why is "How many Kubotas do you have" closed #8
Guess I'm not as fast as I used to be.....
I've just noticed this thread has had some posts removed, I was going to reply to the guy who asked "why so many Kubotas".
Perhaps I'll just state that I think the moderators/administrators do a good job in keeping this site civilized and a pleasure to read and post.
/ Why is "How many Kubotas do you have" closed #10
Thread has been chopped because somebody said "m0der8tor" and somebody else put a link to another tractor board. Geez, unless it got outa hand late last night, dunno why. Was cordial, heck, it was downright complimentary to TBN. Best tractor board on the net.
This was my post:
Usually get a PM as to why when there's deletes.
I did have a valid question. Some others may have as well.
Happy Thanksgiving to you collectors. And the rest of us with lonelier tractors :)
/ Why is "How many Kubotas do you have" closed #11
Now im shaking my head the post numbers are are in order for me.I recall a link. that site didnt look to interesting. to me to be honest
I just dont know anymore
Two of the B5100s are equipped with a compressor, receiver etc for powering the air snips used for pruning vines.
The 4wd B6100 is used for towing the 12V trailed sprayer pictured in the first post, but also for other jobs like this pto powered wire/drip hose winder.
View attachment 146844 When the wire or hose has been wound up the three sections of the cylinder can be released which allows the roll to be lifted off.
The post hole digger frame and gearbox in the above pics also has a bracket I've made which mounts the gearbox on its side. To the now horizontal output shaft I fit a tenching wheel which will dig a trench 18" deep x 3" wide.
I bought the third B5100 earlier this year with a view to converting it to replace this buggy which we use for training young vines, tying up drip hose etc.
Don't know when I'll get time to do that!
Sorry the Winder pics didn't load correctly - here thay are.
2022 Fairbanks Nijhuis Commercial and Industrial Water Supply Pump (A59228)
2022 Fairbanks...
2015 Freightliner Coronado 122SD T/A Day Cab Truck Tractor (A60352)
2015 Freightliner...
IRANCH 15in. Log Grapple Mini Skid Steer Attachment (A59228)
IRANCH 15in. Log...
2025 Kivel 42in Forks and Frame Mini Skid Steer Attachment (A59228)
2025 Kivel 42in...
2026 tilt trailer (A56859)
2026 tilt trailer...
2025 CFG Industrial QK18R Mini Excavator (A59228)
2025 CFG...
