My new Ditch Witch HT25
   / My new Ditch Witch HT25 #1
drw
Jacksonville, TX
Kubota L2800
Last month at auction I picked up a HT25 for $3,000. This is the one with a Kubota engine. It has 494 hours.
Everything on the machine works great, but it seems to lack power. When I start digging a trench and get down to about 18" deep, it starts to bog and if I don't lift the bar it'll actually die on me.
I'm planning to replace the engine oil and hydraulic oil (plus filters). Does anyone have any other ideas as to what would cause this lack of power?
   / My new Ditch Witch HT25 #2
I would change fuel and air filters also. Does it have black smoke under load? Are the hydrolics weak or is the engine? You might have a valve dead heading the pump also check/listen to it while its idleing.
No black smoke under load.
I'm not sure how to determine which one is weak... How would you know whether it was the hydraulics or the engine?
   / My new Ditch Witch HT25 #4
No black smoke sounds like a fuel problem, like cloged fuel filter or bad fuel lift pump. Or you may have something wrong with fuel line.
1st take line off & injection pump and turn the key on you should have a good flow of fuel if not start working your way to the tank.
I'll give it a shot - thanks for the advice!
Well, I've been messing with this machine for a while and am still having trouble finding the problem. (Note, I'm not extremely experienced in working with tractors and engines).
It turns out that I was wrong about what I wrote above: indeed when the machine gets under load, there is a small amount of black smoke being ejected from the muffler. Moreover, it makes some "popping" sounds like it's trying to backfire.
Any thoughts?
   / My new Ditch Witch HT25 #7
Any thoughts?
Burnt valve? I suggest doing a compression test.
   / My new Ditch Witch HT25 #8
Is that a turbo engine?
2018 FORREST RIVER CRUISE LITE CAMPER (A50854)
2018 FORREST RIVER...
2012 Ford F-250 Ext. Cab Service Truck (A50323)
2012 Ford F-250...
2007 FORD F-750XL SUPER DUTY DUMP TRUCK (A51243)
2007 FORD F-750XL...
Caterpillar Front Glass (A50854)
Caterpillar Front...
2009 JACK COUNTY 130 BBL VACUUM  TRAILER (A50854)
2009 JACK COUNTY...
2010 L3 GENERATOR SET (A51222)
2010 L3 GENERATOR...
