Treads - what is it?
   / Treads - what is it? #1
Andy JH
Australia
Luzohng 404A
Reading the owners manual for the B7100D I noticed that above the Tire specifications was a set of figures for Treads.
F 825mm (32-31/64")
R 650-700mm (25-19/32", 27-9/16")
Any idea what they are refering too?
The Tire specs are:
F 6-12 2Ply (20.5x8-10)
R 8-16 4Ply (29x12-15)
I have read all the tire threads here but might have missed some, Like everyone else a while back I am trying to match up front and rears for 4WD use. Found some great info so far but wondered if this 'Tread' spec might be something to consider.
Cheers,
Andy
   / Treads - what is it? #2
The rear seems awfully narrow, but I believe they are refering to the width that you can move the tire/rim assy to make tractor more stable.
   / Treads - what is it? #3
My b7100 operators manual gives the treads spec as 26", 28", 30" .for the rear. Not being able to get an exact measurment but just eyeballing from the back with a tape measure it looks like the holes in the axle shaft that let you adjust the width of the rear wheel hubs are the same distance apart as the numbers listed. So it is my guess that B2400 is correct. Althought the actual outside width of the tire is much greater than the distance specified as "Treads"
Thanks for that,
It sounds about right and I will check it in the next few days.
2025 K4230G UNUSED Metal Storage Shed (A53117)
2025 K4230G UNUSED...
UNUSED FUTURE VR59 59" VIBRATORY ROLLER (A51248)
UNUSED FUTURE VR59...
2025 IR UNUSED Ripper (A53117)
2025 IR UNUSED...
2020 EZ-GO EXPRESS S4 GOLF CART (A51247)
2020 EZ-GO EXPRESS...
2007 HONDA TRX250 RECON ATV (A51247)
2007 HONDA TRX250...
Hydraulic 80 mm pin thumb & coupler combo (A52384)
Hydraulic 80 mm...
