Hello,
I have a JD 4200 with brake problems. As it is fully hydro, the brakes are rarely used except for steering when I use it to clear snow in the winter. It gets driven on the side of the road quite a bit (northern Michigan) so picks up salt from the road. Last year the brakes started sticking on when used. All of the exposed linkage is clean and lubed. Something is binding in the trans. Tried to get some lube in there thru the shaft seals where the brake shaft comes thru the trans case but didn't work. Any ideas without pulling the trans case apart?
Crebb
Crebb
