Will My Tractor Lift This ?
   / Will My Tractor Lift This ? #1
Ductape
Elite Member
Central New Hampshire
Kubota B3030HSDC
My kingdom for a grapple.
   / Will My Tractor Lift This ? #2
Be careful...you can bend the arms of the loader if you try to lift too much...
   / Will My Tractor Lift This ? #3
Forks as opposed to a grapple will give you more lifting capacity with logs. You have a mighty large tree section. I am thinking "divide and conquer" that log with a chain saw.
   / Will My Tractor Lift This ? #4
shouldn't be a problem,might want to cut it in half though !
   / Will My Tractor Lift This ? #5
Going out on a limb here :D But I would have to say, "Just say no" :rolleyes:
I belive that monster would give any tractor a run for its money. Maybe if it can be cut into more manageable sizes :confused:
Make sure to keep extra weight in the back if you give it a try.
   / Will My Tractor Lift This ? #6
Sure, you can lift that. Just be sure to drape the chain over the back of the bucket.
Helps with the center of gravity or something like that.:D
   / Will My Tractor Lift This ? #7
I can't speak for your tractor, but I do know one thing for certain. I could slide my loader bucket under the middle of that log and promptly lift........the back wheels right up off the ground!
That is a pretty good sized chunk of lumber you got there. I think I could handle moving the sawdust as long as I could take it 1/4 yard at a time!
   / Will My Tractor Lift This ? #8
No chance, you'd be lucky to drag that monster..
A different view.......
2019 Allmand Night-Lite V-Series 7kW S/A Towable Light Tower (A52377)
2019 Allmand...
TAKEUCHI TB250-2 EXCAVATOR (A52705)
TAKEUCHI TB250-2...
2017 FREIGHTLINER CASCADIA SINGLE AXLE DAY CAB (A54313)
2017 FREIGHTLINER...
2006 GMC C7500 DUMP TRUCK (A51406)
2006 GMC C7500...
New Holland B95 Backhoe (A50490)
New Holland B95...
2018 CHEVROLET 1500 SINGLE CAB TRUCK (A51406)
2018 CHEVROLET...
