Massey 135 Diverter Valve
   / Massey 135 Diverter Valve #1
justinowens
Hi,
I opened the two bolts on my diverter valve which is located on the rhs just in front of the seat.
There is a long pipe/cylinder going down in to the transmission.
After I bolted it back in place it does not work, the lift arms won't work any more.
It feels like it is not sitting exactly in place - maybe a 1/2 mm or less off but just not seated correctly.
I have played around with it trying to get it to work but no joy.
Any ideas anyone??
Thanks
Justin
   / Massey 135 Diverter Valve #2
It's more than 1/2 mm off, its sitting between the side wall and the hydraulic pump (don't ask me how I know). The oil from the pump flows back into the sump instead of going to your valve.You have to empty the greater part of the transmission oil and then open the round opening on the right side of the tractor so that you can guide the tube back into its hole. Be careful to place the O rings correctly at both ends of the tube and one under the valve. Then pour the oil back into the transmission and you are OK to go.
   / Massey 135 Diverter Valve #3
Sorry this is OT but soulasphil could you please post a picture of the rear of the tractor where the loader attaches?
Thanks.
   / Massey 135 Diverter Valve #4
Thanks.
The loader rests on brackets pinned to the rear axle. It is worked by a single cylinder underneath the tractor. Difficult to make photographs of the relevant parts. Here is what I could find.
   / Massey 135 Diverter Valve #5
I had mine out to replace the O-rings and did not have any problems getting the long tube to seat. Its been a couple of years but think I remember feeling slight drag of the o-ring to know it was seated. If you do pull off the side cover, take some pictures. My pump pressure ocilates so the 3PH goes up with a jerky motion. It would be nice to actually see what the filter sceen looks like. IE should I have a new one before opening it up or can the one in there be cleaned.
UK135, Power steering, 3cyl diesel
   / Massey 135 Diverter Valve #6
If you are very lucky, you can lower the long tube so that it goes straight into the right hole and you don't lose the O ring on the way, but that seldom happens. The safest way to do it is open the round hole with the gauge for hydraulic oil level (red arrow) in the right hand side and guide it with your hand.
You could also do it from the other side, but it is more difficult to reassemble the rear PTO lever correctly afterwards.
2013 BMW 328i Sedan (A55853)
2013 BMW 328i...
2017 KENWORTH T800 TRI AXLE SLEEPER TRUCK (A57880)
2017 KENWORTH T800...
2018 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2018 Ford F-150...
2017 Caterpillar D6T LGP Crawler Tractor Dozer (A55787)
2017 Caterpillar...
Horse Weathervane (A55853)
Horse Weathervane...
CATERPILLAR 21" PIN ON BUCKET (A52706)
CATERPILLAR 21"...
