Kubota L4200 Cab ** Completed **
   / Kubota L4200 Cab ** Completed ** #11
Very nice! Now I'm jealous. :D
   / Kubota L4200 Cab ** Completed ** #12
MCD 176;
The cab looks factory... Very nice. Did I miss the construction shots ? Did you make the supports and cover the remainder with glued on safety glass ? The square look is definately in. Must be the new design kubota. I haven't seen that style. How are you mounting the wiper amid all the glass ... or did you save a section below the roof panel ? Again... great work.
   / Kubota L4200 Cab ** Completed ** #14
Joes427vette,
First of all thank you for the compliments, here is the link to the construction photos:
http://www.tractorbynet.com/forums/build-yourself/147742-kubota-l4200-cab-updated-thread.html
As far as the supports yes I fabricated the entire cab from scratch with 1.5 x 1/8" tube, I then used 3M window urethane to mount the glass, the door is removable as well as the rear 1/4 windows for the summertime
Thanks,
Mike
Could we see some close-ups of the glass attachment? From the costruction photos, it looks like it's just glued to the outside. But then, I thought I read something about you insetting it.
   / Kubota L4200 Cab ** Completed ** #17
Ok everyone here are a few pics of my mostly completed custom built cab
I still have to add my wiper, lights and some other things
Congratulations on your cab.- I went through the thread when you was building it.- You do great work and that's the best looking homemade cab I've ever seen.- I like how the glass is in your cab.- Looks like you have great visibility, and it really looks like a factory cab! -Very well thought out! :)
About the wiper.- Do you already have the wiper motor ?
If not, JC Whitney has some great wiper motors and the price is great.- They are very easy to install, and only requires drilling a 3/8" hole.- And they also have an on/off switch on the motor.
Looking forward to seeing more pics when it's all finished!
Thanks for sharing your project!
   / Kubota L4200 Cab ** Completed ** #18
If not, JC Whitney has some great wiper motors and the price is great.- They are very easy to install, and only require drilling a 3/8" hole.- And they also have an on/off switch on the motor.
I would hope he predrilled the hole before the glass was tempered.:eek:
   / Kubota L4200 Cab ** Completed ** #20
My bad, I was thinking about my cabs both have the wipers mounted to the glass for the rear windows.
GENERAC ST20-S 2IN WATER PUMP (A52472)
GENERAC ST20-S 2IN...
2015 INTERNATIONAL MA025 (A52472)
2015 INTERNATIONAL...
2012 Ford E-150 Passenger Van (A51692)
2012 Ford E-150...
2015 FORD F-450 SERVICE TRUCK (A52472)
2015 FORD F-450...
2006 MACK CV (GRANITE) BOB TAIL KILL TRUCK (A52472)
2006 MACK CV...
BUSH HOG 2810CD SINGLE FLEX WING ROTARY MOWER (A51406)
BUSH HOG 2810CD...
