Erskine Front Mount Blower Hydraulic Cylinder
   / Erskine Front Mount Blower Hydraulic Cylinder #1
Luremaker
Ontario
Kubota L3130HST & NH TC18
I put my Erskine Front Mount Snow Blower today and noticed a leaking hydraulic cylinder. These are welded so replacing the seals is not possible. I am looking for a replacement pair of cylinders with 2" bore x 4" stroke like the ones in the photo. Anyone know where I might be able to find them? I've already checked with TSC and Agri Supply and all my local shops with out success.
Have you tried Princess Auto?
I've tried Princess Auto, TSC (Canada & USA) and all the local hydraulic shops in my area. Most don't stock small cylinders and some have never seen this type of hydraulic cylinder before. I am still waiting for prices from Erskine. They do not seem to really want to sell direct to me but rather to a local dealer.
   / Erskine Front Mount Blower Hydraulic Cylinder #4
I too was going to say princess auto not sure why you can't adapt one of there small cylinders to work.In there Fall and Winter Catalogue on Pg 6 they have a 1 1/2 bore cylinder with 4" stroke for $154.99.Again I'am sure it could be made to work.On the other hand when I was looking at yours I'am almost wondering if its a single acting cylinder?? As always Larry.:)
   / Erskine Front Mount Blower Hydraulic Cylinder #6
They look like the same cylinder used on the skidsteer blower, I can take a look when the sun comes up. If it is I have one on a blower here and I can check pricing and ship one out to you.
Your model and serial would be helpful.
Ken
Ken
Hi Ken, the model is Erskine 600FM and the serial # is 4537. I am looking for 2 cylinders with 2" bore x 4" stroke pin hole double acting type. The part number in the 600FM manual is 103273. Steve
   / Erskine Front Mount Blower Hydraulic Cylinder #9
I have one I could pull off a skidsteer blower or could have a couple here next week. It does'nt have 2 on the deflector does it?
Call me 807 275-6722
Hi Ken, These cylinders are actually to lift the blower and not for chute control. If you look at the front frame break down chart it is part #13 and there is a pair of them. Both of mine are leaking a little. Steve
   / Erskine Front Mount Blower Hydraulic Cylinder #11
Ok
They had your part # in stock, I would have to double check if its the same as the deflector one I have, if you wanted it.
But if you need two, I have to order anyway.
$288 cdn for the pair plus tax and freight.
Ken
   / Erskine Front Mount Blower Hydraulic Cylinder #12
Is there a way to modify the lift mechanism to use some cylinders that are more standard and rebuildable?
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
(20) WOOD PALLETS (A60432)
(20) WOOD PALLETS...
2014 CATERPILLAR 930K WHEEL LOADER (A60429)
2014 CATERPILLAR...
2004 Volvo VNM S/A Day Cab Truck Tractor (A59230)
2004 Volvo VNM S/A...
2014 Magnum 7696BLA Light Tower (A59213)
2014 Magnum...
2018 Buick Encore SUV (A59231)
2018 Buick Encore...
