I have only disconnected mine about 3 times, when my hyd pump went bad, (Brother pressure washed it and damaged a seal when he did.) I rebuilt the pump with factory seals 3 times and it would not work right, ended up with a NEW pump...
servicing the factory disconnects is no big deal, but there really is nothing to go wrong with them, (other than what greg said) and if they POP apart when connecting/disconnecting you always have to make sure the sliders are fully seated forward (towards the two halves.). great safety item is to take a 1/4" wide wire tie and tie around the back slider part of the QD so that it cannot come apart without cutting the wire tie off... this has been a long time fix, someone posted it long ago and I've done it ever sense.
I think someone already mentioned that the relieve valve part of the FEL will bypass the spools and direct fluid back to the return port. this is safety system and prevents spool pressure build up. the passages are all internal to the valve.
I have several posts and made a good bit of documentation, JOHN S used to post here a lot, his page has a lot of good info
johnstractor
several links & posts from different people there that John compiled several years back. It is rather old but has very good info for JINMAs look for the "JINMA INFO" and then "JINMA MAINTENANCE" buttons for some good reference tasks...
Mark
Mark, what is a wire tie?
