4x20 series vs 3x20 series cab space?
   / 4x20 series vs 3x20 series cab space? #11
I do wish i had a larger property footprint as I really did like the 4x20 series for stability and power.
   / 4x20 series vs 3x20 series cab space? #12
I do wish i had a lager property footprint as I really did like the 4x20 series for stability and power.
Hey if you can turn it around in your driveway what other justification do you need?:D
   / 4x20 series vs 3x20 series cab space? #13
I could but Man, that 4x20 series is really a lot larger and cannot fit in my shed:(
Yes i did think about it.
   / 4x20 series vs 3x20 series cab space? #14
Get it with a Cab. :) No shed needed. Or alter the shed door, but still get the cab. :)
   / 4x20 series vs 3x20 series cab space? #15
Indeed, the 4x20s have massive power for their size and can be used for commercial tasks that previously required larger machines. A 66hp 4720 is more powerful than many larger machines and can use heavy commercial implements that used to be off-limits to compact tractors.
The downside is cost though, 4x20's are not cheap and quite thirsty. You can get a larger tractor for less.
I don't think you can get a larger similarly equipment tractor for less.
I have a 4520 cab and really like it. If I had to do it over, I would go R1s instead of R4s.
D.
   / 4x20 series vs 3x20 series cab space? #16
I feel the same goes for the 3x20's.....(well the 35 & 3720 at least)...
I thought about the 4x20 as well...what "killed it" for me was the power & size...I didnt really NEED that much HP for my 2 acres, and the 4x20 wouldnt/couldnt fit in my garage while the 3x20 does.
Taking all the "thoughts" in this thread...the perfect tractor for me (and sounds like Nuru too) would be a 3 1/2 x20 ... Height of the 3x20, width of a 4x20, neighborhood of 35-40 horseys... Would be the Goldilocks of tractors...not too big, not too small...
   / 4x20 series vs 3x20 series cab space? #17
Sorry, I meant you can get a tractor with a larger frame but less engine power for less.
   / 4x20 series vs 3x20 series cab space? #18
Oh don't you temp me, my banker will get really mad at me for that, but it would be fun LOL! I did like how high it sits up and just looks overall a lot stronger unit
   / 4x20 series vs 3x20 series cab space? #19
Spudland_Dave, yep, we essentially are working with the same operational environment and made the same decision. That perfect tractor is too much though LOL!:D
   / 4x20 series vs 3x20 series cab space? #20
First buy her a real nice gift, forgiveness may come easier. :)
2016 Kubota SVL75-2 (A53317)
2016 Kubota...
1998 REINKE TRAILER HEAVY HAUL TRAILER (A58214)
1998 REINKE...
Bell 1600 Gallon Nurse Trailer (A56438)
Bell 1600 Gallon...
Unverferth Road Runner Head Cart (A59814)
Unverferth Road...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
WOOD GRABBER FOR MINI EXCAVATOR (A58214)
WOOD GRABBER FOR...
