MF 1600 Series - What neede for radio install??
   / MF 1600 Series - What neede for radio install?? #1
WilliamBos
Super Member
Innisfil, Ontario, Canada
MF 1635 12x12 Powershuttle
Hi All,
Was wondering what is needed to install a radio/CD in our MF 1635?? Do we need to buy a harness, or is it all there??
   / MF 1600 Series - What neede for radio install?? #2
If its a cab tractor, the harness is there. However, there are only a few radios from your MF dealer that will directly plug in. Otherwise you can purchase a radio locally, cut off the factory connector on the tractor and splice the harness yourself.
Thanks. Yes, it is a 1635 Cab, and saw some nice priced MP3 cd's (Sony) in Walmart. So just cut off MF plug, and splice?
Thanks.
   / MF 1600 Series - What neede for radio install?? #4
gosh William, getting spoiled already aren't we? :D
   / MF 1600 Series - What neede for radio install?? #6
Hi Will,
You really should get one of the newer systems with bluetooth, ipod and HD Radio. Some of the radios with navigation (might not need on a tractor) have a small hard drive that you can store music on instead of messing with CD's in the cab. But the bluetooth for your phone is a must.
Check out Crutchfield.com or some of the others before you buy.
Bruce
Update...
One for Power, One for speakers.
So will this direct fit??
   / MF 1600 Series - What neede for radio install?? #8
No direct fit unless you get an overpriced, under impressive radio from AGCO. Get your test light out & find your constant power, ign. feed, & ground on the one plug, and the speakers should be on the other. You may have to get an antenna from your friendly MF dealer though.
what about a wiring harness??
   / MF 1600 Series - What neede for radio install?? #10
The ones I've put in, the adapter harness didn't work anyway. None were AGCO radios, they were all from the local electronics place. Just used the supplied harness with the radio & made it fit by cutting the tractor ends & splicing.
2006 TerraGator 8104 (A53472)
2006 TerraGator...
Intermodel Metal Storage Crate (A51573)
Intermodel Metal...
2009 Kaufman Gooseneck Trailer and 10K Hydro-Blast (A50860)
2009 Kaufman...
2017 Nissan Altima (A51694)
2017 Nissan Altima...
2015 Ford Taurus AWD Sedan (A51694)
2015 Ford Taurus...
