SPYDERLK
Super Star Member
- Joined
- Feb 28, 2006
- Messages
- 10,345
- Location
- VA
- Tractor
- JD2010, Kubota3450,2550, Mahindra 7520 w FEL w Skid Steer QC w/Tilt Tatch, & BH, BX1500
If you have a 100 psi tank, it stands to reason that's where you should be operating it at. This has to do with cutoff/cut-on range that's been discussed, and more importantly, with the air charge. As Spyderlk has pointed out, the tank is charged with air pressure just below the rated cut-on level.
So, if your tank is factory set for an 80 psi minimum, you'll need to compensate for this if you lower the pressure on the switch, otherwise you could empty the water tank completely as the switch comes on. (fraction of a second, as the pressure drops from 70+ to nil on the last few ounces of water.)
Then again, if you had your 100 psi tank in service out there already AND had it operating at the lower pressure range, then the installer likely made the air adjustment in the tank.
Shemp... Still there?? What this says to me is that your precharge is set right at or maybe a hair above cuton pressure. Try bleeding off a 10 sec hiss of precharge air... Or preferably, turn the pressure adjust nut 1 turn CW to increase cuton/cutoff a little. Does that greatly improve your low pressure performance?What happened was apparently my neighbor came over to wash his horse and changed the settings. I got out to the land today and noticed that the guage was pegged at 100psi. I started to let out the pressure when the pump kicked on at 80psi. I wasn't too sure where the original settings were set when I had it put in. Kinda pissed me off when I saw the guage. The only issue I seemed to have was when I got it down to 60/40 it just really lost pressure when it got close to 40 to turn the pump on.
larry
