Rick_CT
For me, the garden tractor with snow blower has worked fine. I have 550 feet of paved drive, some uphill. I had a 12 HP wheel horse with plow for years, much of which was before paving the drive. It never let me down, but once I upgraded to the 22 hp wheel horse, I couldn't belive the difference the size made. First, having a hydraulic lift for the attachments makes things so much easier, especially when you have to the lift a plow over and over. As you get older, you appreciate letting the machine do the work. Second is just the sheer size and weight of a larger machine, makes moving the large snows so much easier, with less of a beating on the equipment. I plowed for years, then purchased the blower. It can throw snow at least 50 feet, and the nice part is you don't have to deal with snow banks, and where to put the snow during a heavy winter. With the hydraulic lift, I could set he blower to run above the surface if needed, such as you suggest on the gravel drive. Last year I added the cab, again, I can't belive the comfort level something so simple and basic affords. Getting out of the wind, and not getting wet is real nice. With 18 inches due tonight, it will get a work out tomorrow. I have added some pictures of the setup I am using, plus one with the mower deck on it as well. I have 3+ acre's, with over one of grass, and the machine cuts grass with no problem, and no damage to the lawn. I think that the 22hp size machine fits my needs perfectly. I do have a toro 1132 walk behind blower, 11 hp with 32 inch cut. This machine is a real chore to use. I bought it before I added the blower to the tractor just in case we got more snow than the plow could handle. I have used it a number of times, but it is so big and heavy, I'm sore for a few days after each use. I will probably sell it this winter. Good luck finding something that will do the job for you. Rick.
