Jumping Glow Plugs
   / Jumping Glow Plugs #1
JoelD
Windham, NH and York, ME
Kioti LK3054xs TLB, 2004
Is it possible to jump a glow plug? Can you use jump pack and hook negative to engine block and postive to the glow plug to get them hot?
Thanks,
Joel
   / Jumping Glow Plugs #2
interesting concept- never heard of it being done, but why would you need to do that ? Only thing I seen is youtube showing how to test the glowplugs out of the engine with battery.
   / Jumping Glow Plugs #3
I have "hot wired" glowplugs from a tractor's own battery a few times. In instances of a faulty key switch or similar problem, I can get the tractor running and moved to a more suitable place to do a proper repair. I've been known to run a jumper wire to a fuel shutoff solenoid for similar reasons. Something about working in severe conditions when it's unnecessary becomes less appealing as the years pass.
   / Jumping Glow Plugs #4
You would be better off to use some 10ga wire and a switch that is only on when pushed called a "momentary on".
Chris
   / Jumping Glow Plugs #5
Chris
I don't hardwire them. I disconnect the glowplugs when the heat cycle is complete. A jumper wire with alligator clips is all I use. 'Momentary on' in a different fashion.
2012 DOOSAN G25KW GENERATOR (A55745)
2012 DOOSAN G25KW...
2017 Ram 1500 Pickup Truck, V6, 4X4, Automatic Transmission, 212,570 Miles (A56438)
2017 Ram 1500...
2016 Doyle 10T Tender (A56435)
2016 Doyle 10T...
Cushman Electric Cart (A55851)
Cushman Electric...
2009 CHEVROLET C8500 DUMP TRUCK (A59823)
2009 CHEVROLET...
2000 Case 590 SL Backhoe Loader (A59814)
2000 Case 590 SL...
