Rolled my tractor....Engine won't turn over!
   / Rolled my tractor....Engine won't turn over! #11
Try removing the glow plugs along with the injectors and then see if you can turn the engine manually. $800.00 for a starter!!!!!!!
   / Rolled my tractor....Engine won't turn over! #12
No,tried to turn over manually and nothing. Wondering if it has to do with the hydrostatic transmission. It seems like a pressure lock of some kind because when I first tried it manually I was able to turn it a half turn and then it locked up. No grinding noise and again no debris of any kind in the oil. Thanks for the reply Will
HST should not have a bearing on whether the engine will turn by hand but on the other hand if you are starting it with the starter then yes some linkage issue or switch may prevent the starter to engage.
$800 to rebuild a starter? What's a new OEM worth?
Man that's scary.
Good luck with your troubleshooting
DGS
   / Rolled my tractor....Engine won't turn over! #13
Take a day off with the tractor in the upright position. Pull the injectors and see if it will turn over. :D
Then get on to the serious stuff.:D
   / Rolled my tractor....Engine won't turn over! #14
there should be a way turn the crankshaft over by hand [ie with a wrench] at the front of engine.it should turn over fairly easy if you still have injectors out.place trans in neutral and give it a try.if you indeed got it shut off right away I would think it should not have done any damage inside the engine. If it ran for a minute or longer with no oil presure than damage could be done,but when you shut it off I would certainly think it would have been making some noise.
   / Rolled my tractor....Engine won't turn over! #15
The same thing happened to my BX24. I was very concerned that I had ruined the thing but I was able to fix it with no long-term damage. I pulled the glowplugs, hand cranked it with a wrench on the flywheel for several revolutions, then cranked it with the starter for a bunch more until no more oil was flying out of the glowplug holes. I put the glowplugs back on and it fired up and has been running great ever since.
It was acting exactly as you describe. When cranking with the key, the flywheel would move a little bit, then move back when you let go of the key. I'm betting you'll be fine.
Thanks rdsaustintx,Cheap "E" ticket ride!
Curtis thanks again for the rply. It does have a clutch safety but the display tells u when it is depress to allow it to turn over.Could that be faulty? Clutch seems to have little movement from released to engaged about 4 inches.Will check seat safety and the PTO cable.HST linkage: should I put it back up and if so should there be free spinning wheel rotation no matter what? And $ 800.00 starter...gotta love Hawaii...they gothca coming and going
Try turning it over in neutral with a pipe wrench on the fly wheel. 1/2 turn then nothing
Is there a way to disengage the HST so I can eliminate that as a cause?
   / Rolled my tractor....Engine won't turn over! #19
Have you checked the safety switch on the seat. Just a thought.
You think it flipped or broke? Would that allow the starter to engage even though it was not working,because the starter engages but no turning of the motor....will check in the morning
2010 DODGE RAM 2500 FLATBED TRUCK (A51247)
2010 DODGE RAM...
2007 International 4300 (A53314)
2007 International...
2005 Jeep Wrangler 4X4 SUV (A55758)
2005 Jeep Wrangler...
2013 Ford F-150 Pickup Truck (A53422)
2013 Ford F-150...
2007 MACK CTP (GRANITE) ROLLOFF (A56129)
2007 MACK CTP...
2014 Freightliner 108SD Utility Truck with Crane and Rail Gear, VIN # 1FVHG5CY3EHFL1495 (A54865)
2014 Freightliner...
