Light, Medium, Heavy Duty Attachments...
   / Light, Medium, Heavy Duty Attachments... #11
Just an FYI, I drive a 45 pto hp tractor and bought a medium duty brush hog from woods. It's great and has been really put to the test with no problems. I did notice that if you buy a smaller (< 72") one in the same (medium duty) line that they use lighter duty blades and other parts.
   / Light, Medium, Heavy Duty Attachments... #12
Hey Pitt_md,
Which model Woods mower did you get. We've been looking for something to put behind the DX60.
I drive a YM-21010D, similar in terms of weight and power. I have a small stable of Yellow TSC implements - KK; and I believe that these are well suited to tractors like mine. I have not had any issues whatsoever, and I use this equipment extensively. With about 250+ hrs on my Box Blade, SSoiler, Finish mower, RCutter, and Carryall, the equipment has performed admirably. I believe that this line is advertised as appropriate to use for up to 30 HP. I don't know about that, but it has handled my use very well.
As has been noted, there is little in the way of standards in this line of work, and some folks appear to be comfortable labeling all of company X or Y's equipment as 'good' or 'not good', without reference to the product line, or intended use. I have investigated other manufacturers sold in the area; there is a dealer who carries Great Plains and Woods, definitely premium manufacturers with a great rep, but honestly if you are comparing apples to apples on a product to product basis, there's little justification for me to pay 1.5-2x the price for essentially the same thing. While there were apparent differences in the finish of 3pt equipment, I was not impressed with the differences in material, weight and design to justify the cost difference.
I think in general terms, 3000 lb and 24 HP would be considered 'light duty' by most implement manufacturers, or at least it's at the bottom of their matrix for the equipment they design. For the most part, with 4-5' implements, there's only a few options for Medium or 'HD' implements on most product lines. If you were gong to use specific items in adverse conditions, or commercially, going to a Med or HD version may be warranted. And of course, these definitions are highly subjective. While I use my equipment responsibly, I also push it to do what needs to get done. I live in an area with rocky, hilly, difficult ground. Frankly terrain that many would consider difficult or crazy to even use a tractor in. Still, the "regular", 'standard', or 'light'
duty KK stuff has held up well.
On the other hand there is some equipment also labelled 'light duty', that is clearly designed and priced for intermittent use with lower-powered equipment. These tend to be knock-off brands or product specifically designed for use with BXs etc, and that light duty class might work well with a BX, don't know, but I suspect it would be compromised quickly with something bigger and heavier, regardless of HP rating.
Very well said. Thanks for the reply.
My experience reflects yours.
   / Light, Medium, Heavy Duty Attachments... #14
Hey Pitt_md,
I got the 72" Woods Heritage model HSS72. I did replace the blades after 3 years of finding stuff hidden in the weeds.
   / Light, Medium, Heavy Duty Attachments... #15
In the light duty/medium duty/heavy duty discussion, I might add that what is light duty for one tractor, can't be torn up by another. I had quite an impressive collection of implements for my Ford 1100 4x4 and could do just about anything to them/with them that I wanted. When I got my JD 2555, I proceded to tear up a good portion of those implements just in general use, as the implement became the wear link instead of the tractor's horsepower. Keep this in mind when somebody recommends a particular brand/model of implement for your operating pleasure, as they might fall into a catagory such as I did. My little Ford 1100 didn't have the power to tear up a lightweight implement no matter what I did with it, but the larger tractor has no problem destroying them whenever it takes a notion.
Couple horsepower differences with operator habits and you add in a totally different set of rules. After all, there are guys that own implements that they use for years and never scratch the paint on, and then there are the guys that can tear up a steel ball bearing with a rubber mallet. If you are one of the rubber mallet guys, then you might want to consider getting a little heavier duty implement as insurance. By the way, weight alone isn't the only factor in deciding what is heavier duty, as strenght is often "engineered in" to an implement. Shop, Shop, shop, looking at different implements, including used ones, as a used one should tell you where the weak points of a particular brand/model are, which should guide you in your search.
David from jax
   / Light, Medium, Heavy Duty Attachments... #16
I decided to start this thread rather than hijack another.
As I understand it, when purchasing attachments, things to be considered are the weight of your tractor and horsepower.
Let me cut to the chase...My tractor is 24hp, 4x4 and weighs roughly 3,000lbs.
Are light duty attachments a good match for my tractor.??
Yes, a GOOD MATCH.
   / Light, Medium, Heavy Duty Attachments... #17
It depends on how much & how hard you are going to use it. If your getting a bushhog to mow grass off field a few times a year LD, if your going to be knocking down small brush than Med. or HD. I think the average home owner that's not going to be abusing his own equipment would be fine with LD stuff. Everybody wants the best of the best but sometimes your wallet won't let you do it!!;)
   / Light, Medium, Heavy Duty Attachments... #18
In my experience I have learned that I am best off going for the heaviest duty stuff that my tractor can handle from a main line manufacturer.
This is what has worked best for me. I bought a Kodiak rake and the thing just came apart. Welds on the gauge wheels broke. Tines broke and I barely use the thing 5 to 6 times a year for my driveway and manure cleanup.
   / Light, Medium, Heavy Duty Attachments... #19
My experience is that a well built tractor, employed firmly, will promptly tear up any light duty implement that is not just plain too big for the tractor. A medium duty implement will last quite a while under the same circumstances before the tractor tears it up. I have never had an implement that did any better in relation to the tractor. Basically, a tractor will eventually tear up anything you would put behind it.
larry
   / Light, Medium, Heavy Duty Attachments... #20
IMHO it has more to do with matching the implement to the tractor.
brush hogs and box blades have a rule of thumb of about 5hp per foot.
for your SCUT 4' implements are going to be the norm.
a 4' light duty BB is NOT going to be the same as a 6' light duty BB. the forces on a 6' BB are much larger than a 4' BB. If you put a 6' light duty behind ya your unlikely to be able to 1) pull it 2) impart enough force on it to break it with your current SCUT.
one other thing to consider, if you ever see yourself buying a larger tractor in the future, you might consider that when purchasing implements now. While a 4' light duty may work now, its going to be undersized if you go to a class 1 CUT (AND way undersized if you go to a class 2 CUT)
but if your happy with your current SCUT and have no plans for future expansion, then youll do fine with light duty implements.
2002 Freightliner FL112 E-One Pumper Fire Truck (A51692)
2002 Freightliner...
2011 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2011 Ford F-150...
2014 GMC Sierra Pickup Truck (A50323)
2014 GMC Sierra...
JOHN DEERE TS 4X2 GATOR (A51406)
JOHN DEERE TS 4X2...
2025 JOHN DEERE Z325E LOT NUMBER 84 (A53084)
2025 JOHN DEERE...
2008 John Deere 608C combine head (A50657)
2008 John Deere...
