Broken Joystick on 7108 FEL
   / Broken Joystick on 7108 FEL #1
captaincrab55
Maryland
1715 Ford & many more
I've got a 1715 Ford with a 7108 FEL.. The machined pin broke that supports the yoke that the joystick pivots on... I went to the New Holland Dealer on the south side of Baltimore... They could only pull up the valve and couldn't offer any suggestions as to where to get the part... I'm looking at making a repair that would replace the pin with a metric bolt.... I'm looking at grinding, drilling, hack-sawing and welding... Right now I'm stuck trying to get the pin out that holds the joystick in the yoke.. Looks like the pin is a press fit. Tomorrow I'm going to mount a small arbor press, to press the pin out..
Can one buy that part?
Is there an easy fix without a metal lathe?
Is that pin supposed to be a press fit?
Thanks, Tom
   / Broken Joystick on 7108 FEL #2
here is the parts breakdown. and a copy and paste of the relevent listings. The main support pin is part of the valve mount plate.
1715 3 CYL COMPACT T / 05H02 2-SPOOL REMOTE CONTROL VALVE & PIPING KIT, W/7108 LOADER
Key Qty Part Number Part Name Description
2 1 86514022 PIN Pin, Spring, Start Year: 01/01/1987
3 1 SBA030102016 PIN, SPLIT (COTTER) Pin, Split, Start Year: 01/01/1987
4 1 9824259 WASHER Washer, M6, Start Year: 01/01/1987
5 1 SBA344220440 PLATE Plate, Start Year: 01/01/1987
6 1 SBA036800012 RING, SNAP Ring, Snap, Start Year: 01/01/1987
7 1 SBA340080100 LEVER Lever Assy. Includes: Ref. 8, Start Year: 01/01/1987
8 2 SBA398511270 BUSHING, DRIVE Bushing, Start Year: 01/01/1987
9 1 SBA340800700 BRACKET Bracket, Start Year: 01/01/1987
10 3 N602550S36 BOLT Screw, HH, W/Washer, CL 8.8, M8 x 1.25 x 25, Start Year: 01/01/1987
11 4 86729275 WASHER, LOCK Washer, Lock, 5/8", Start Year: 01/01/1987
12 1 SBA340800640 BRACKET Bracket, 1320,1520,1620,1715, Start Year: 01/01/1987
12 1 SBA340800730 BRACKET Bracket, 1720, Start Year: 01/01/1987
13 4 86508583 BOLT Bolt, Hex, M16 x 35, 8.8, Start Year: 01/01/1987
14 1 SBA340330230 COVER Cover, Start Year: 01/01/1987
15 5 86511828 SCREW Screw, Pan Hd, CL 4.8, M6 x 1 x 12, Start Year: 01/01/1987
16 1 SBA340210580 SHAFT Shaft, Start Year: 01/01/1987
17 2 SBA030300632 PIN, SLOTTED PIN, SLOTTED, M6 x 32, Start Year: 01/01/1987
18 1 SBA398112750 BOOT Rubber, Start Year: 01/01/1987
19 1 SBA340103670 LEVER Lever, Control, 1320,1520,1620,1715, Start Year: 01/01/1987
19 1 SBA340103700 LEVER Lever, Control, 1720, Start Year: 01/01/1987
20 1 SBA030303532 PIN Pin, Spring, Start Year: 01/01/1987
21 3/2 SBA011510820 SCREW, CAPTIVE WASHER SCREW, CAPTIVE WASHER, Hex, M8 x 1.25 x 20, G5, Start Year: 01/01/1987
22 2 86511315 WASHER WASHER, M8 x 16 x 1.6, Start Year: 01/01/1987
RickB, That's it, the diagram I thought the dealer should have... They didn't have a clue at the Dealer... Thanks!!! Now if the Dealer can get it before the next snow?
   / Broken Joystick on 7108 FEL #4
If they are a New Holland dealer, they had it.
Having and finding apparently are two different concepts.
   / Broken Joystick on 7108 FEL #5
There are dealers,and there are dealers that have someone that can help.That should have been easy to look up if you had model & serial number off tractor.Someone did not know how,or did not want too.IT CAN MAKE OR BREAK A BUSSINESS.Good Luck
The young lady that waited on me did pull up the diagram for the loader... She did ask an older guy for help, he looked for 30 seconds and walked away.. Past experiences there were poor service and steep prices.. I bought an oil filter 3 years ago there right after I got the tractor... The filter cost was just under $10 and they were out of stock... I've been to that Dealer 4 times and never left with what I went for except on the return trip... I should look for a Dealer elsewhere and just pay shipping. It's an hour round trip and $4.00 in tolls for poor service.. Time to find a new Dealer.....
   / Broken Joystick on 7108 FEL #7
The valve is an accessory to the tractor; it won't be found by searching the loader. All two spool valves for NH compacts are cataloged that way.
   / Broken Joystick on 7108 FEL #8
Try Messicks; they are on this web site often and can assist you in anything you need and have the knowledge to to help you get the correct part.
Thanks for the Heads Up.....
VERMEER NAVIGATOR 53 D23X30111 DRILL (A51406)
VERMEER NAVIGATOR...
2005 CATERPILLAR 740 - 6X6 OFF ROAD WATER TRUCK (A52706)
2005 CATERPILLAR...
2018 E-Z Beever M12R Towable Brush Chipper (A51691)
2018 E-Z Beever...
2011 Ford F-350 Knapheide Stakebody Flatbed Truck (A52377)
2011 Ford F-350...
2000 WINNEBAGO FORD F550 RV (A52472)
2000 WINNEBAGO...
