BX1860 4 season review
   / BX1860 4 season review #1
winddance
Member
In case anyone is searching I thought I would do a quick review of my Kubota bx1860 on my Minnesota vineyard. I have the front end loader and 54 inch deck. And, of course, the engine heater.
Background: 600 foot gravel driveway with hills and curves. 2 acres of vineyard. 4 acres mowed. Live on a lake. Had used a bobcat 610, an atv for spraying and the largest garden tractor Sears sold (the monster).
The hydromatic drive in the Sears tractor died completely 1 month after the warranty was up. Sears would not help at all in the cost of the rear end or labor. To repair it would cost $900 if I did the work. I checked the net and discovered Sears put the lightest duty transmission on their heaviest tractor and there were dozens of postings from others with the same exact problem (and it still had a higher rating than the JD!). I decided not to fix it since I would definitely need to fix it again in another year or 2. So, I decided to get a machine that could replace the bobcat, the dead lawn tractor and the atv - And I sold all of them.
1) Mowing: Much more comfortable and did a better job than the Sears. Fit perfectly between the grape trellises and had a much higher clearance - So I never bottomed out. There are only 2 negatives: It takes a few seconds for the blade to engage and the mower deck will drift down when all the way up (only when not in use). Handles the hills excellently. I give it an A- on mowing.
2) Moving dirt. Ok, it can only carry 1/4 to 1/2 of the dirt that the bobcat could carry. If I have too heavy of a load and I am on the hill it has a tendency to roll to the right. On the other hand, I used it to carry dirt to places my bobcat couldn't go because it was too heavy - Down by the lake I moved about 6-10 tons of class 5, and moved several tons of used hay (per animals) to the compost pile up, down and around hills. Yes, it didn't carry as much, and it was a little unstable when overfilled, but, I never would have been able to do those things with the bobcat due to wet ground by the lake and damage to the lawn, etc. Grade it with a B. Higher if I was smart enough to stay within the limits of the machine.
3) Snow with the FEL and rear chains (gave up on trying to put front chains on). Ok, I almost bought a snowblower when I got the 1860. Then I thought I should get a back blade. Then I decided to just try the fel first. I have been plowing snow with my bobcat's fel for about 20 years and thought it was the perfect machine. After our 17 inch snowfall I am starting to think the 1860 with the fel is better. The bx1860 can move faster. Because the bucket is smaller I can push the snow just as far as I could with the bobcat. It still takes 3 trips down the driveway with pushing the snow off the side every once in awhile. It is much more maneuverable so I can clean out places that were very difficult to get to before. But, did I say how much faster it is? Got it done in 1/2 the time. Grade for snow removal with the fel and rear chains: B+. An A would be someone else doing it. Oh, hint for plowing: The bucket needs to be very slightly tilted up from level for most plowing. The bucket should just slightly touch the ground. When on a hill, tilt it down slightly to scrap down to the gravel so you will have better traction with the cars.
4) Spraying: I'm a wimp. The first time I sprayed with it and saw the layer of semi-permanent residue on my beautiful orange machine I groaned. It handled the spraying perfectly. Better than anything else I have used. It was very easy to keep a steady speed. But, I hated wrecking the paint. So, I picked up an old riding lawn tractor from craigslist for free and converted it to a sprayer. Oh, one funny thing: My sprayer uses a 12v battery. I connected the battery to the tractor battery in parallel so it wouldn't go dead (plugged it into the 12v outlet). Then I couldn't shut the tractor off! I finally unplugged the sprayer and it went off. Seems the power in the dc outlet also powers the fuel pump, etc. Funny.
In summary, I made the right decision getting the 1860 vs the 2360. I was pretty nervous about it thinking I needed the higher horsepower. Never once have I thought I needed more horsepower. A little wider would be nice for on the hills, but then I would have a harder time between the grape vines. I like it so much I sometimes find myself wanting a second one. I don't know what for, but when I get something that does what it is designed to do I always want a backup.
Oh, had 1 problem. Once the temp gauge pinned to the hot end, but dropped down again when I tapped it.
   / BX1860 4 season review #2
Nice review and I have a couple of comments.
Your deck shouldn't drift down. If you set the level with the adjustment knob, is should lock the deck at that height, and not rely on the hydraulics to hold it up.
As far as the FEL goes, you can get a bucket expander from a company called BX-panded that would help you with your capacity. You couldn't use it for heavy stuff as it would overload your machine, but for lighter weight stuff it would work well. If your machine seems tippy, you need some kind of counter weight out back or fill your rear tires with fluid.
I find a rear blade works better for snow removal. I just angle the blade and shove the snow off to the side. I know this works well as long as you don't get alot of snow, since if you have alot of snow, it builds up along the sides and you don't have any where to push it.
Thanks! I agree. The deck only drifts down when it is parked for several days and lifted all the way to the top. Never drifts down from where it is set or past where it is set if sitting. I think I will be filling my rear tires in the spring. I can see where that would help with the loads and the stability.
   / BX1860 4 season review #5
I went with wheel weights on my BX2660 in lieu of a liquid due to experience with our Ag tractors and losing the fluid due to punctures as well as aggravation when changing or repairing tires.
   / BX1860 4 season review #6
I am into my second season with my 1860, and haven't had any issues at all. The machine exceeded my expectations in mowing and far exceeded them with the front blower. Two of my neighbors purchased orange units this last summer after looking over mine.
Bill
   / BX1860 4 season review #7
nice review- however if you add liquid ballast to BX rear tires, it will feel better on the hills with stuff in FEL. Have you thought about getting BXpanded add on bucket to carry more in the FEL ? I too noticed same issue with mower deck drift down when you don't use it for a long time.
   / BX1860 4 season review #8
Great review. I just bought mine with a fel. 50 inch snowblower, 48 inch belly mower. I only have 10 hours on it, mostly moving wood and one last cut. I will be moving my compost pile this weekend. I was planning on removing the belly mower and fel soon and put the snow blower on to get ready for the snow. I must admit its nice to have the fel even though its been used only for light duty. By the sound of your review, I hope I will not be sorry that I purchased the blower. I have aprox. 400 feet of stone driveway with slight inclines and some ruts. Definately not flat blacktop. So far I am very impressed with the feel of it. Your review and reply threads are all making me drool to put it to the test.
   / BX1860 4 season review #9
dabull I just bought a new BX1860 and have about 10 hrs on it as well! I love it! I've used it a little harder though, digging out 2 small tree stumps and some digging and leveling of my lot out back. Waiting for the box blade I ordered to come in so I can try it out! I just can't believe how much these little machines can do, but I always have a big smile on my face while I'm doing it!
   / BX1860 4 season review #10
PAlittleKub so do I. How did you attack the stumps. Was it just with the fel or did you have a backhoe.I have a couple of scotch pine stumps and other shrubs that we would like to pull out, this is all new to me
id all new to me. So if you h
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
2001 Freightliner FL70 Truck, VIN # 1FUBBUAK21HJ24793 (A51572)
2001 Freightliner...
STOP!!!! PLEASE READ ALL TERMS BEFORE BIDDING!!! UPDATED TERMS!! (A50775)
STOP!!!! PLEASE...
UNUSED RAYTREE REDM32-32" EXCAVATOR DRUM MULCHER (A51248)
UNUSED RAYTREE...
ITEM LOCATION LOT NUMBER 3 (A53084)
ITEM LOCATION LOT...
New Wolverine Skid Steer Forks Attachment (A53002)
New Wolverine Skid...
