790/3005 - anyone with a mid-mount mower?
   / 790/3005 - anyone with a mid-mount mower? #1
bxowner
Gold Member
Vermont
John Deere 5055e
I can't seem to find any info or pictures of a mid-mount mower on a 790/3005. I'm debating the merits of a larger tractor and may pass up the convenience of the hydrostatic in favor of the higher output engine and PTO that comes with the gear drive. But, I need to mow with the tractor.
Can anyone give me real-world experience with mowing with these tractors using a mid-mount? I have too many obstacles to use a rear-mount.
Thanks.
   / 790/3005 - anyone with a mid-mount mower? #2
I use a 4400 with a mid mount 72 inch deck and I like that combo quite a bit.
   / 790/3005 - anyone with a mid-mount mower? #3
Keep in mind that you may have to add the mid PTO to the tractor.. That will run ~$900 to the .. Do you really need the MMM, what about a rear finish mower instead..
Brian
I don't think the rear finish will work because of how many trees I have. I'm really debating the gear drive, too, because of the number of trees I have. I know I could wind it way down into low range, but there's only so much time in the day to mow. By the time I add the mid-PTO, I'm probably pretty close $$-wise to a 2520.
I have yet to find any pictures or info about a mid-mount mower on this website. Someone's got to have this set up! Right?
   / 790/3005 - anyone with a mid-mount mower? #5
I use a 790 with a rear 7 ft mower and have a B7800 Kubota with a six ft belly mower and an HST. I use the 790 to go under a tree line and big areas in a hurry. The B7800HST is a dream mower to go around obstacles. I never had an HST and didn't think I would like them. Now, I love it.
I thought of the 790 and getting the mid-pto kit. There is a SN break in the 790 and the early sn kits are technically obsolete but some dealers still have them for the $500 area. I almost went that route and glad I didn't because of the gear trans and the hassle of shifting.
The HST, in my view, will become the only trans available in time because it just works so well. Just my two cents.
   / 790/3005 - anyone with a mid-mount mower? #6
If you have too many obstacles for a rear mount mower then likewise you wan't a hydro transmission.
I'm not trying to sell you anything but want to throw out this idea about the range selection issues, the 2520 hi range is too high to use for most work as others have mentioned. One nice thing about the X748 is it is a single range from 0 to 8.5mph. This may work better for mowing. You might be able to get your loader chores done and then buy a mower that is optimum for what is left to do. Just a thought.
   / 790/3005 - anyone with a mid-mount mower? #7
Thanks.
How about a rear finish mower?? I agree on the non- hydro, would not own one ever again!! :)
   / 790/3005 - anyone with a mid-mount mower? #8
When I was in the process of purchasing a new tractor in the fall of 08', I was contemplating the same setup that you are. Currently, I was cutting 7 acres of my total 11, with a 72' IH Cub. It was an 11 hp tractor (I know seems low as heck, but it would turn a 5ft belly mower without a problem as long as it was running like a top and the mower had sharp blades), with a 3 speed (not including reverse), gear mesh transmission. The only real gripes I had about it were that it was under powered (really though that was only if you didn't stay on top of cutting the grass), and it was slow (the fastest you could cut grass was in 2nd gear, which I would estimate was around 3 mph at pto speed....yeah I know, talk about slow, it would take me 7 - 8 hours to totally cut the place, now it takes me 3 - 4 with the 3320), but the biggest gripe was that it had seen it's "time", it was worn and it was old, and I was tired of fixing it. For the past 3 season it had had something go wrong with it that wouldn't allow it to run at its top performance. Insert buying a new tractor
My first choice for a new tractor was the 790/3005 (790 is the previous model, 3005 is the new production model which is just a 790 with the 3005 badges). I liked the simplicity of it, the price, and the gear mesh transmission. I was used to shifting and didn't mind it so I never even placed the hydro on my radar, I was content. But, there were a few reservations with the 790, such as the weaker hydraulics and the issue of the mid mower only working with the R1 tires. In the end I ended up passing over the 790/3005 and going to the more efficient gear transmission that is the PowrReverser on the 3320 (you should check one out, no clutching when changing directions and gears can be shifted while in motion, but that's another story for another time).
Overall though, I think a 790/3005 would work perfectly for your needs. But, the mid pto will most likely have to be added by the dealer or yourself, depending on where you buy it and which ever you prefer. Even with adding the mid pto and a mid mower, I don't think you could justify the extra cost of the 2520. I would also suggest checking out the 3032e or 3038e if you plan on buying new. They're value line tractors that come standard with a 2 speed hydro transmission, (I suggest at least test driving a hydro so you get an idea for one) and the option of a frame mounted loader (as opposed to the removable, quick-tach loaders).
Good luck with your purchase.:cool:
   / 790/3005 - anyone with a mid-mount mower? #9
Have you considered Used units versus new? You probably can get into the unit you want that is out of $$$ reach new.
2019 Ford F-350 4x4 Ext. Cab Palfinger PSC 3216 4,000lb 2 Ton Mechanics Crane Service Truck (A50323)
2019 Ford F-350...
2019 Ram 2500 Pickup Truck, VIN # 3C6UR5DL0KG545677 (A51572)
2019 Ram 2500...
P.T 1000 Gallon Supply Tank (A50120)
P.T 1000 Gallon...
2018 Jeep Grand Cherokee Multipurpose Vehicle (MPV) (A51694)
2018 Jeep Grand...
1991 Ford L8000 (A50120)
1991 Ford L8000...
2014 MAGNUM PRODUCTS LIGHT TOWER (A52472)
2014 MAGNUM...
