Hand warmers on a snowblower?
   / Hand warmers on a snowblower? #1
Lickity Split
Germantown WIsconsin
MF65, Toro Groundsmaster 72
I have a older ( 10 years old) John Deere 828 snow blower, with a 8hp Tecumseh engine on it.
It is 110 volt electric start (no battery) and it has a head light that comes on when the engine is started.
Can I get a set of hand warmers like on a snowmobile, and wire them into the head light?
I was looking at a set from Dennis Kirk made by Polly the specs say the light system was to be 75 watts or better.
How do I tell how many watts my light system is?
Thanks Lickity Split
   / Hand warmers on a snowblower? #3
75 watt handwarmers may be a bit of a task for your engine. What motor do you have (HMSK80)? Later OHV motors had higher output coils that could handle handwarmers and lights.
   / Hand warmers on a snowblower? #4
I might buy the chemical hand warmers that fit inside your gloves. Very toasty lasting 6 to 8 hrs. and likely alot cheaper/easier than retro fitting electric mounted handle warmers.
I have an older (pre-MTD buy out) Troy Built snow blower. Unit is equipped with control handle warmers. All time on/electrical operation, with engine running.
I would expect most MTD mower/parts dealer could still order the necessary retro parts for handle warmers. My unit has wiring routed inside the handle tubes, offering good protection.
Hope this helps.
   / Hand warmers on a snowblower? #5
Hope this helps.
The machines I have seen have had a single wire coming from berhind the flywheel if they are headlight only and two wires (one heavy, one light) if it was setup for lights and handwarmers.
Aaron Z
2000 John Deere 1860, 30ft Wide, Gandy Box, Wing Fold, 7.5in Spacing (A53472)
2000 John Deere...
BW RVB3405 20,000lbs 5th Wheel Hitch Base (A50322)
BW RVB3405...
Flatbed Utility Trailer (A52377)
Flatbed Utility...
2014 CATERPILLAR CT6605 SBA 6X4 DUMP TRUCK (A51406)
2014 CATERPILLAR...
JOHN DEERE 1725 CCS (A53084)
JOHN DEERE 1725...
