arps 80 to go on a tc30
   / arps 80 to go on a tc30 #11
Army grunt ,
I did a search and could and did not find anything.
the one i saw was a small one it goes on a 3 point hitch. i have one i just bought, but the pins are really bad, i was just thinking if the one i saw that was still tight exept for the hydrolicks all burnt off, i could swap some stuff out.just thinking out loud.:)
Falcon
   / arps 80 to go on a tc30 #13
Falcon
Can you show pictures and explain what pins you are talking about. Just about anything on the BH can be rebuilt.
I was just thinking out loud about it. Yes on replacing the pins. sadly someone welded one in, AN never put a grease fitting in it. I have a friend that can design stuff on his putter an have the pieces cut at an shop with a plasma cutter. he has already told me we can replace any part. also i have a southbend lathe so i can make my own pins. The burnt out one would have given me a really pristeen start for a 100%+ rebuilt. Ill work it frist an fix as needed.....I got all the stuff needed from the newholland dealership for the rear hyd. hopefully tomorrow ill give it a try, today i sawed some pine out for a local guy.
Grunt
   / arps 80 to go on a tc30 #15
Here's the post I remember about a burnt backhoe. I don't think he was looking to sell it - maybe he has it rebuilt by now.
http://www.tractorbynet.com/forums/attachments/140778-identifying-backhoe.html
I like a thin cutoff wheel for cutting through welds e.g. on a 3" air cutoff tool. Depending on the geometry an angle grinder might do it. Worst case you have to replace a welded bushing and pin?
If you have a bushing that needs a grease fitting drill and tap it for a 1/4-28 zerk. Even if you have do drill a ways into the pin to use the tap it won't hurt anything.
that was it , tks brad.A fellow gave some advice on the seal being not good after the fire. I am not sure ill get involoved with burnt out stuff.
Grunt
2023 John Deere 408R Sprayer (A53342)
2023 John Deere...
(1) HD 24ft Free Standing Corral Panel (A51572)
(1) HD 24ft Free...
2022 John Deere 4066M Heavy Duty MFWD Tractor (A53342)
2022 John Deere...
City of Buckhannon - 2005 Volvo Garbage Truck (A52384)
City of Buckhannon...
ROME GK-14 LOT NUMBER 131 (A53084)
ROME GK-14 LOT...
2014 Ford Escape (A50323)
2014 Ford Escape...
