Welding and brake clean hazard
   / Welding and brake clean hazard #1
trialsguy
Kansas City Mo. area
YM226D
This may have been posted before but I just found out about so I thought I would pass this very important message along.
Brake clean when heated say while welding will emit a very dangerous gas
here is the link Brake Cleaner = Phosgene Article
I use brake clean all the time and easy could have done this
   / Welding and brake clean hazard #2
BAD, BAD news. You may be in need of medical help NOW!!! Treat it as a HART ATTACK, if left untreated you may have lung problems a year from now.
No I didn't have this happen to me, I am sorry I wasn't clear when I posted but I wanted to get the info out fast. A buddy of mines co-worker was welding I assume on a elevator since that's what he does for a living, While welding he welded into brake clean which I guess he used to remove grease or oil and it puffed up and now they don't think he is going to survive, his kidneys liver and lungs are shutting down and has some sort of nerve damage he is on some sort of support. Very very bad, I hadnt ever heard of this so I wanted to pass it along as quick as possible
   / Welding and brake clean hazard #4
Sorry to hear about your friends condition. This subject has been discussed on welding forums before. It dose not take much to get into trouble, some guys just get a small whiff and get a little light headed, shrug it off and two days later are on life support. Even if you wipe the cleaner off some may be left behind in crakes and crevasses just waiting to get you. There are other cleaners just as dangerous. Do not think about treatment at the end of the day when you have time, it is off to the ER NOW!!! You could be a Macho-man with a toe tag.
   / Welding and brake clean hazard #5
Thanks...good to know!!:eek:
Deano
   / Welding and brake clean hazard #7
same thing happened to my ex-boss in a bike shop about a year ago, nasty stuff. his website has a pretty detailed article about it, check out brewracingframes.com
   / Welding and brake clean hazard #8
Doesn't brake cleaner flash off faster than just about anything on the planet, at least the good ones, that's why we use it for cleaning jobs other than brakes.
Unless it's the newer eco friendly types, I don't see how you could "weld into it" Unless you had a helper spraying it 4 inches in front of your bead. Or is it the residue left behind?
Sorry, I didn't read the whole link.
Not to down play it, as that warning on the can sounds pretty ominous, but did you ever read the side effects of the medicines we put in our mouths :eek: or the warnings right on the welding rod package.
JB.
   / Welding and brake clean hazard #9
JB.
No doubt about it all being bad stuff. The problem with break cleaner is that as it decomposes at high temperatures the by-products are deadly. If it did as you say, we would not be posting these stories about the dangers.
At onetime we feared Lions, and Tigers, and Bares....oh my! Now bad things come in small cans.
   / Welding and brake clean hazard #10
JB.
From some evidence on some of these poisonings that have occurred, apparently the fluid can hide in crevices and rust pits and be vaporized by the weld arc.
Enerpac Hushh-Pup Hydraulic Power Unit, Model Per-132, Product Code B14880, 1/3 HP, 120 Volts, 1 (A59076)
Enerpac Hushh-Pup...
2025 AGT H15R Mini-Excavator with Dozer Blade & Pilot Controls  (New/Unused) (A59225)
2025 AGT H15R...
SAKAI SV414D SMOOTH DRUM ROLLER (A52709)
SAKAI SV414D...
2013 TYTAL CRUDE TRAILER (A58214)
2013 TYTAL CRUDE...
2013 FREIGHTLINER CASCADIA (A58214)
2013 FREIGHTLINER...
72in Bucket Skid Steer Attachment (A56857)
72in Bucket Skid...
