Roof Slope Question
   / Roof Slope Question
The one area we see felt in a completely failed state is on the slate roofs we work on. After 80 to 120 years especially on the south sides it literally turns to dust and pretty much just leaves a black residue/dust, making those roofs susceptible to wind and ice causing leaks, even as steep as they are.
I would suggest that under shingles the felt wouldn't last that long either. The only reason you don't see felt failures under shingles is that the shingles fail first...
   / Roof Slope Question #22
Yeah, but now we have some manufacturers selling "lifetime" rated comp
shingles (TimberLine). I have heard that some of the these triple-laminated
shingles can be quite lumpy, however.
In our area, Dave, there are many roofs as low as 2.5/12 since we have
no ice damming or snow loads. Many of these roofs get converted from
tar/gravel to comp shingles and legally do so by doubling up the
underlayment and cutting off the "Dutch gutters". My new house is
mostly 3:12 with dual-laminated comp (class A) 40-year shingles. My
barn I did with standing seam steel (Western Metal), which required
a 3:12 minimum pitch.
Some of our jusidictions in the Bay Area still allow shake roofs with NO
underlayment. Menlo Park did, as recently as the late 90s.
Your 4:12 is more than adequate.
   / Roof Slope Question #23
You mentioned the insulation factor and your roof pitch. What insulation method/material are you going to use?
Also, Grace ice and water shield is a great product but you don't need to use it on your whole roof. There are other similar products to use on the rest of the roof surface that cost much less and get the job done. You would still use the Grace on the valleys etc. There is roof top guard 2 that comes in 5 foot rolls and gets cap nails from a gun, vs sticky backing. It is better than felt paper by far and keeps out water,etc. I just did my entire 1200sq.' addition and my 30' .deep x 40' wide barn/apartment in the combo of the two products. Since then we've had all kinds of high wind driven rain, snow sleet, etc. with no problems. We used an IKO Harvard slate 30yr. architectural shingle. Don't waste your money on a 40 year shingle- you won't be using it, and it will not be worth anymore to a potential buyer. I've yet to see anyone get a useful 40 years out of a shingle job. As far as insulation goes if you do a sealed airtight roof with no soffit or ridge, or gable end vents and use closed cell spray foam you can do preconstructed trusses and get exactly what pitch you want by having your local lumber yard do the formulation for you and print a set of construction drawings. You will pay more for the spray foam upfront but it will be a big selling point to your buyers and it will be returned on your investment when you sell.
   / Roof Slope Question #24
Rebuilding my burned out house, I am having to jump through a lot of hoops the Town is putting up.
One is that in many places I can not increase the overall height of the house, not even by an inch.
The problem that I am facing is that my old roof was built 100 years ago from 2x4 rafters. To get the right insulation in I have to go to 2x10, which is 6 inches thicker. Combine this with 2x10 floor joists instead of 2x6 and a couple of other problems, and I have to lower the roof peak by ~12".
One relatively painless way to do this is to just lower the roof slope from 5 in 12 to 4 in 12.
Does anyone have any experience here. I suspect that a 4 in 12 roof is going to be more leak prone than a 5 in 12, but is it a big difference or a small one?
Foregiveness is easier than permission. A 4-12 isn't that much different in functionality vs the 5-12. I would not worry about leaks because of slope. Construct any roof (slope) correctly and leaks will not be a consideration, regardless.
   / Roof Slope Question #25
   / Roof Slope Question #26
Are you going to use fiberglass insulation to achieve your r-39? If you use high-density spray foam you could probably use the 2x4 rafters and 2x6 joist. The spray foam will give higher r-factor per inch. Spray foam I believe is used alot on the west coast because of the weird restrictions. Good luck, codes are always a pain and enforced by idiots who do not know what the **** they are talking about.
   / Roof Slope Question #27
May I ask why bother rebuilding if you are just gonna turn around and resell it ? will you actually realize a profit ?
   / Roof Slope Question #28
I'm not the world's best carpenter so I may be missing something. Why does the size of your rafters increase the height of the roof? A 5/12 pitch is a 5/12 pitch regardless of the rafter being a 2x4 or a 2x12.
5/12 means for every 12 inches of width the roof goes up 5 inches from the starting point. The starting point can be the same regardless of the size of the rafter. The bottom of the rafter would be lower but the top would not be higher.
In the case of replacing a 2x4 rafter with a 2x10, you just cut the bottom of the rafter where it meets the wall at an angle where the top of it is even with where the top of the 2x4 rafter was.
I can go in a house with 2x4 rafters and replace a rotten one with a 2x10 rafter without raising the roof height at all.
My options are very limited.
As a buildable lot, but with a foundation already in place, the value of the property is minimal. The only real potential buyers are contractors building spec homes, who are pretty scarce these days. And, who are going to negotiate hard for a bargain basement price for the house.
Plus a lot of the previous structure did not conform to current setback requirements. It is not at all clear to me that a buyer could build a home nearly as large as the one I can build, since I am allowed to duplicate the previous structure.
In most real estate markets, the most common item for sale is a single family home. This is the item of commerce which will command the highest price.
By building, I get to put the largest possible home on the lot and I believe that I will make a substantial profit.
   / Roof Slope Question #30
I built my own home years ago from plans from a catalog. The plans called for a 4/12 pitch which as others have said is common for ranches. I live in a heavy snow area so I used 5/12 trusses 2X4 truses. In 35 years with winters with as much as 12 feet of total snow, I have never had a problem. Why the need for 2X10's for insulation. My insulation is laid between the trusses and sticks up into the air. It doesn't matter how thick you go. Am I missing something. Vaulted ceilings, maybe?
2010 Lincoln MKS (A50324)
2010 Lincoln MKS...
2002 JOHN DEERE 450H CRAWLER DOZER (A51406)
2002 JOHN DEERE...
2016 Ford Explorer AWD SUV (A53424)
2016 Ford Explorer...
Manac Walking Floor Trailer (A50322)
Manac Walking...
2018 Ford Fusion Hybrid Sedan (A53424)
2018 Ford Fusion...
2007 International 4300 Dump Truck (A51692)
2007 International...
