Roof Slope Question
   / Roof Slope Question
While I can (and will) certainly increase the birdmouth, there is a limit to how far this works. Anything beyond where I get a full seat of the rafter on the top plate is going to lead to problems on the inside of the wall. Either the sheetrock will not fit properly, or I must cut a more complex birdmouth, and the ceiling height at the wall will be less.
Due to what the people who estimated the job call "site conditions" it is not reasonable to use trusses, the roof is going to be stick framed with individually cut & placed rafters.
The only access to the site is across a 3' wide wooden pedestrian bridge 30' long. Once you get across the bridge, you are at the first floor level, and must raise the roof materials to the top of the second story. Sure, enough guys could horse the trusses across the bridge and maybe even lift them up, but it is a lot easier to stick frame it. The bridge crosses a narrow but deep ravine and it is not possible to get heavy equipment across the bridge without extraordinary effort (and extraordinary expense). There are only 46 rafters in the whole house. I might be adding 2 or 3 days for a skilled carpenter to cut & place the rafters. At $25/hour for the framer I stick frame it and move on.
   / Roof Slope Question #42
trusses are going to solve all your issues.
spray in expanding foam gives much better R values that wont require 2x10 rafters to achieve.
trusses can also be built on site with portable presses.
the most common application is to bring in sections that are easly handled and the last few joints feild pressed with a portable press. (there are various versions but the most common is a tool that looks like a jaws of life but in the form of a HUGE C clamp. running off a remote power pack)
   / Roof Slope Question #43
Did you know that roofing felt and most shingles is recycled newspaper? impregnated with tar? and as the tar dries ir becomes brittle and that is when the shingles start to fail.
Same with 'felt underlay', it dries up and turns to powder with age.
Personally I believe underlay's origional existance was to even out the surface back in the days when tounge and grouve was used as decking and since we nowdays use plywood or sheet decking the requirement no longer exists.
Shingle makers being faced with rapidly rising costs of recycled paper looked to alternatives to get better cheaper finished products and that is what brought on the flexible membranes to the marketplace.
Also shingles used to be rated by years of expectancy; eg 10 year, 20 year etc but nowdays they wish to be rated by the weight/sq.
Guess the mfgs got fed up defending lawsuits for roofs that leaked prior to 'advertised expected life span'
Standard bundle covers 33 sq ft, 3 packs per 100 sq ft so calculating roofing is real easy (in most cases) however I once had the client purchase the shingles and he bought the heaviest 'double' type.
Due to OSHA requirements, the heavy shingles need to be 6 bundles/square because of weight.
Well 1/2 way into the job I needed to re-order as we'd be short 50%.
Learning curves!
Never heard felt or shingles were made from newspaper. I suppose some manufacturers might use newspaper as one of the ingredients. That may be why a certain manufacturer's shingles are junk.
I've torn off many a roof where the 25-30 year old felt was just like day one. It will deteriorate rapidly if exposed to the weather though....like if the roof is leaking.
I've replaced roofs that didn't have any felt. There weren't issues with them leaking, but the owners reported that the shingles didn't last as long as they thought they should.
The shingles sold around here are still advertised by life span. 30 year, 40 year, etc.
Some shingles are 3 bundles to a square, some 4,etc. Order by the square and you don't have to worry about getting the correct number of bundles.
   / Roof Slope Question #44
$25 an hour? Going rate around here is about double that, but it should take much less time.
   / Roof Slope Question #45
I've seen allot of 15 lb felt paper that's brittle and falling apart. Never seen it with 30 lb paper.
Here, trusses are not as common as rafter built roofs. Most of the time, I think it's more up to who the builder is, then the span, in decide which way to go. For big rooms, I've seen allot of glue lams used, and then built up from those beams.
Trusses are sure allot faster, but if you got an interesting roof line, then they don't really save any time. Especially if you want a hip roof or some dormers!!
Sorry to hear you won't be posting any pics of the build process. I've found that posting pics is helpful in finding problems that I can fix, or address. Sometimes the comments don't really apply, but when you get a good one, they are sure worth it!!!
Hopefully you'll post a few pics of the finished house???
Eddie
   / Roof Slope Question #46
rafters to achieve.
Sounds cool. I've never seen one of those portable presses. Who makes them? How much do they cost?
   / Roof Slope Question #47
Eddie, Do you think the higher temperatures in your area contribute to the felt becoming brittle? I would think the heat would cause the felt to dry out faster.
Pops
   / Roof Slope Question #48
I think that all attics in summer get pretty hot, and a dozen or more degrees either way shouldn't make much of a difference. I don't know how old those roofs where with the brittle paper, but I've had allot of issues trying to slide flashing under it. I can almost guranetee that the paper will crumble on me if it's the thin suff.
I think 15 lb paper should be illegal on a house, but it's not and they use it all the time around here. Even thought it's half the price of 30lb paper, it's not even close to being half as good.
Edide
   / Roof Slope Question #49
While your high temps might not be that much higher than ours, you certainly have more days with high temps. I think the prolonged heat is a contributing factor.
That's why I think 30# might be more beneficial in your area than here. 15# is pretty much the standard here although I've used 30# at times. One customer spec'd 60#!!!!! It's hard to justify requiring 30# when most properly installed 25 year roofs are lasting 28-30 years with no problems.
While I feel its important to use a good quality felt to get the full life out of a roof, I think some guys use it as a crutch to get by with poor workmanship when installing a roof. For instance, I see guys using it for valley material. Thats just a leak waiting to happen! I've also seen guys use felt for flashing around dormers instead of using baby tins (step flashing). Its amazing the shortcuts some guys will take.
I promise I will post pics of the finished house.
Adams 5T High Clearance Fertilizer Spreader (A55301)
Adams 5T High...
2019 MACK PINNACLE P164T DAY CAB ROAD TRACTOR (A51406)
2019 MACK PINNACLE...
2012 Ford F-350 4x4 Knapheide Utility Flatbed Truck (A51692)
2012 Ford F-350...
Adams Tender / Magnolia Trailer (A55301)
Adams Tender /...
2019 TIGERCAT 234B TANDEM AXLE DE LIMBER (A54607)
2019 TIGERCAT 234B...
