Plumbing question
   / Plumbing question #11
You all made me get up and go look, cause I couldn't remember where I ran mine. :D
My outside wall (kitchen sink) comes up thru the floor. Interior walls are via the wall. I think that is code here, have to ask my plumber friends...
   / Plumbing question #12
I'm a licensed plumber. I think the interior petitions should be run in the wall. As time has gone by I have found that my opinion is not binding, however. I do think that where possible an access panel should back up that wall. For instance, does the tub/shower have a closet behind it? If so, put an access panel there. It is easier for the plumber to simply stub up through the floor, but you give up storage space. Not a popular option with "she who must be obeyed"...if you get my drift.
A bit of info for you. I recently remodelled the 3 bathrooms in the house. The upstairs baths are back to back and have within a couple feet of each other the same amount of pipe to the shower. Same valve/showerhead. The kids bath is piped with pex and the master with copper. There is a significant decrease in water pressure in the kids bath. This is due to the brass fittings at approx 5/16-3/8" ID crimped inside the pex, effectively bushing down the pipe size. The copper is 1/2" ID and the system performance is much better.
ONe thing I added to our master was a Toto toilet, imho, the best. To that I attached the Washlet 300 seat. Now you may laugh but a heated seat is nice and I shave my head, so a wash and dry on the other end is nice!:D
How are you heating your hot water?
   / Plumbing question
AHNC
After much study I decided to keep it simple and I am going with a standard electric water heater. After working as a Ultra-pure water technician for the last fifteen years, when I found out that the tankless units needed to go through a descaling cleaning on a regular basis, I said screw that.
Cary
   / Plumbing question #14
AHNC
Cary
The descaling depends upon your water quality. I'm assuming that you know what you have there so well enough.
As to your elec water heater, if you are not going with tankless or solar, I would strongly recommend a hot water heat pump. Tax credits will pay for it and it will reduce you bill substantially.
   / Plumbing question #15
AHNC, I to am a plumber, in Illinois. They have just adopted PEX into our code. The thing they did here ,that is a double edge sword, is make us size all piping by the ID of the smallest fitting. So we have to run 3/4 " PEX where we run 1/2" copper and 1" for 3/4" etc. The 1 1/4" PEX is a real pain.
What do you do with the heat pump water heater cooled air in the winter?
They haven't started using them here yet. I just want to be up on them when they do.
So far the tankless units are having some issues around here with build up. The water savers get plugged and cause short cycling. Or they cut corners and put in too small a unit and the flow restrictors cause issues when using multiple hot faucets.
   / Plumbing question
Did some research on the heat pump water heaters and they are saying to only use them in 40 to 90 degree climates. Also, seem to be in the development stage and more geared to commercial applications. Educate me AHNC, but know that I am getting to old to be very adventurous. :D
Cary
   / Plumbing question #17
Need help from the plumbers and others. I'm ready to hire a plumber for the house we are building. I'm real pleased with one candidate, but he runs the supply lines from the crawl space to sinks, etc through the floor instead of in the wall. His point of being able to fix potential problems in the future is well taken, but seems to me that it makes a much cleaner install coming out of the wall. What do you all think?
Cary
For interior walls its standard practice to run supplies in the walls. Exterior walls the supplies come through the floor so they don't freeze. You won't have any problem with properly installed copper supplies in interior walls. There are prefab bumpers (air chambers) with tee's available to cut down on the number of sweat joints in the wall.
Just don't run supplies horizontally in the walls or you'll run the risk of a drywall screw going through a pipe.
According to code (at least in this area) S traps are not allowed. That means the sink drains go through the wall.....they could go through the floor but a P trap would have to be tied into a tee with the vent routed from the top of the tee back into the wall then upwards. That would be a very messy looking rough in.
   / Plumbing question
Pops,
Everyone is using CVPC for supply lines around here. I'm more comfortable with it than Pex.
Cary
   / Plumbing question #19
If you're talking new vs. renovation construction you can spray foam the wall cavity where pipes need to go through the wall instead of the floor. Of course living in the real south you probably don't have too much need or use for spray foaming as a way to insulate- but it is the absolute best approach to insulation bar none. It is costly to do a large area up front but it pays off over time going forward year after year.
We're using a BASF closed cell foam in my new barn, and the addition on the house. The barn is just about insulated now, (and with NO sheetrock yet), and outdoor temps in the mid 30's we are not using any heat, unless a door is opened for a while. Temp is set at essentially off on barn/garage t-stat at 55 degrees. Most of the rough in plumbing is run under the floors and in a large chase that has access from underneath and a cleanout access too. Bathrooms etc. are run inside interior walls with access if necessary. Pex is good for radiant heat, and it has good flow characteristics due to essentially no elbows, etc.
   / Plumbing question #20
I'd just add if you have a "problem area" when a cold snap comes thru - being prepared with a 100W incandescent light bulb will usually get you thru. In an enclosed area such as under-counter it will generate nearly 100W of heat for pennies per day.
The time-tested solution of course is to leave a slow drip on the faucet in question but somehow I find that harder to remember or seemingly more wasteful. Also can present problems where there is a toilet involved as those seem to "trickle" at every time except when you really want it to :D.
2018 KENWORTH T880 (A53843)
2018 KENWORTH T880...
2011 Ford F-350 Knapheide Service Truck (A51692)
2011 Ford F-350...
2025 IR IRMC 8D UNUSED Massage Chair (A53117)
2025 IR IRMC 8D...
2016 Case 821F Articulated Wheel Loader (A51691)
2016 Case 821F...
JOHN DEERE 1725 CCS (A53084)
JOHN DEERE 1725...
2007 National RV Dolphin 35FT Class A Motorhome (A51694)
2007 National RV...
