Planning for a Hydraulic top link- 18.5" to 30" at longest. 5/8" bore for 40 HP CUT?
   / Planning for a Hydraulic top link- 18.5" to 30" at longest. 5/8" bore for 40 HP CUT? #1
Slacker
Gold Member
Durham, NC
Farmtrac 360 TLB
My cat1 toplink is 18.5" at it's smallest and 30" at it's longest.
I'd like to replace it with a hydraulic toplink.
Will this one work? It's 18" at smallest with a stroke of 12", so 30" at it's longest, same as my toplink. Is 5/8" rod large enough to handle a 40HP CUT, 6ft BB and bushhog?
Thanks for the input guys, I only want to do this once if I can help it.
https://www.surpluscenter.com/item.asp?UID=1504011712210785&item=9-7257-12&catname=hydraulic
Double acting
Bore x stroke 1" x 12"
PSI max. 3,000
Rod dia. 5/8"
Ports SAE 6
Retracted length 18"
Shpg. 7 lbs.
END MOUNTINGS
Rod end swivel-ball
Ball width 1"
Ball O.D. 2"
Pin hole 1/2" ???
Base end swivel-ball
Ball width 1"
Ball O.D. 2"
Pin hole 1/2"
   / Planning for a Hydraulic top link- 18.5" to 30" at longest. 5/8" bore for 40 HP CUT? #2
Re: Planning for a Hydraulic top link- 18.5" to 30" at longest. 5/8" bore for 40 HP C
The pin hole is too small, plus you will probably need something with a rod diameter greater than one inch and most everyone recommends a lock valve.
I recently purchaced this one:
https://www.surpluscenter.com/item.asp?UID=1208011713260905&item=9-7682-08&catname=hydraulic
Here is one slightly longer:
https://www.surpluscenter.com/item.asp?UID=1208011713260905&item=9-7682-11&catname=hydraulic
CCM has similar units.
Wow, that website is a pain for those of us who are Hyrdaulic newbies.
I don't think I want the lock valve. I don't mind making slight adjustments
occasionally, especially for $75 extra dollars. Can you point me to the
2X11X1.18 CAT I HYD DA TOP LINK CYL without the lock valve?
I'm having a hard time finding it. thanks for the help!
   / Planning for a Hydraulic top link- 18.5" to 30" at longest. 5/8" bore for 40 HP CUT? #4
Before I bought my cylinder with the lock valve, I priced others without. Mostly the cylinders were close to the same price or higher (see eBay search "top link cylinder"). I also believe the lock valve adds a layer of safety to the setup.
Surplus Center does have this:
https://www.surpluscenter.com/item.asp?UID=1208011718221208&item=9-7259-10&catname=
But the pin holes are are too big (you can buy bushings) and perhaps the whole swivel eyes are too large.
The Surplus Center searches I use are "top link" or "toplink" or "swivel eye". You get different things with each search, but I think it covers it all.
You can also buy a regular welded cylinder and cut the ends off and weld on swivel eyes, but the cost will add up on you quick.
Here is one from another vendor, but its retracted length is longer than I wanted.
Hydraulic Top-Link - Category 1
And a picture of my setup.
   / Planning for a Hydraulic top link- 18.5" to 30" at longest. 5/8" bore for 40 HP CUT? #5
Check this thread if you missed in a search
http://www.tractorbynet.com/forums/hydraulics/161082-hydraulic-top-link.html
I got the Dalton one and love it. It does not have a lock valve and for what I use it for it it is not necessary. Depending on your needs, it may be a necessity. The thread addresses some of the issues.
Dave
   / Planning for a Hydraulic top link- 18.5" to 30" at longest. 5/8" bore for 40 HP CUT? #6
I have a Dalton top link to. It is a cat 2 for my 5103 JD and doesnt have a lock valve either. Works good for what I use it for. It is more expensive than the surplus center brand. Mine is a Prince cylinder with a 3" bore x 10" stroke..... Bull
2009 Chrysler Sebring LX Convertible (A50324)
2009 Chrysler...
1991 Grove RT740B 40-Ton Rough-Terrain Crane (A51691)
1991 Grove RT740B...
2018 Infiniti QX30 Premium SUV (A50324)
2018 Infiniti QX30...
4-27x10.5-15 Hauler Skidloader Tires & Rims (A50774)
4-27x10.5-15...
2020 Kubota Z723KH 48in. Zero Turn Commercial Mower (A50322)
2020 Kubota Z723KH...
2025 Swict 84in Bucket Skid Steer Attachment (A50322)
2025 Swict 84in...
