Tires 1910 rear turf tire chain dilemma ??
   / 1910 rear turf tire chain dilemma ?? #1
Kevin M
Gold Member
goshen NY
48" bobcat walk behind , 60" Dixie Chopper Classic , 755 John Deere 4x4 70 ldr belly mower etc etc , 7610 Ford 4x4 7412 ldr and 10 ft rhino hogg
When i bought rear turf tire chains for my 755 john deere i paid around 300$ bucks, put them on, no problem. So when i saw a brand new set of peerless rear chains for my 1910 i jumped on them for a 150 bucks , I thought what a score! Now the bad part is they rub the fenders, I could move the fenders in slightly, or have some 8 lug spacers made ( looks like an 8 on 8 span ) ( there go's my bargin ) and no i cant flip the wheels there centered ! Any suggestions guys ?????:confused:
   / 1910 rear turf tire chain dilemma ?? #2
are you 100% sure that they are centered? My 1620 with turfs looked like they were centered but when I measured it there was about a 1" difference. Flipping the tires let me run the chains.
   / 1910 rear turf tire chain dilemma ?? #3
yes u need weel extions
   / 1910 rear turf tire chain dilemma ?? #4
On the 1710 w/turfs that I had the chains had to be pretty tight, but not overly, to clear the fenders. Also ensure that your tires are not overinflated. Otherwise you'll have to go as the others have said.
   / 1910 rear turf tire chain dilemma ?? #5
The rear wheels on my 1910 are adjustable, you should be able to remove the center disk and move the wheels side to side for several width adjustments.
Bill
I would gain a half an inch flipping the wheels , but the do have welded center's
   / 1910 rear turf tire chain dilemma ?? #7
You don't need much. Here is my 1620 with the wheels flipped and the tire chains on. I made them tight by taking out a link or two, and but tensioners on the outside of the chains (outward facing part of the rim). It works as they don't flop around.
16FT box truck (A53424)
16FT box truck...
Woods PF4448S 48in Forks and Frame Skid Steer Attachment (A52377)
Woods PF4448S 48in...
Hilti TE 2000-AVR Electric Jack Hammer (A52377)
Hilti TE 2000-AVR...
2023 HarbinGer V3 Plus 8KW S/A Towable Light Tower (A52377)
2023 HarbinGer V3...
Splash 10ft 2,100 Gallon Water Tank Truck Body (A52377)
Splash 10ft 2,100...
2013 FREIGHTLINER EXT CAB SERVICE TRUCK (A51406)
2013 FREIGHTLINER...
