TT75A - 12 volt outlet install
   / TT75A - 12 volt outlet install #1
muskeg_mapper
I have a 2009 TT75A and I'd like to install a 12v outlet to plug in my cell phone cord. Has anyone done this on a TT75A? Is it a big job? My only real question is what wire to tap into to get power to the plug.
Thanks.
   / TT75A - 12 volt outlet install #2
Thanks.
Why not go straight to the battery? Zip ties should make it pretty clean.
   / TT75A - 12 volt outlet install #3
if you want a temp install, radio shack makes a power outlet with gator clips.. just hook to battery and remove when not needed.
otherwise find a hot bus in the fust block and tap power there and use chassie ground.. can use a blade fuse piggy back tap to grab power from an existing circuit.. like headlamps.. etc..
soundguy
   / TT75A - 12 volt outlet install #4
soundguy
That's the way I did mine, not sharing but just put it in a blank slot, was the easiest way for me.
Don't know why these very expensive machines don't come with an auxiliary power outlets.
JB
   / TT75A - 12 volt outlet install #5
JB
TT's are economy tractors. You get what you pay for. Sometimes you get less than you pay for. Mount the socket with the opening facing downward so when the cover disappears, debris and moisture doesn't become trapped in it.
2007 International 7400 Chassis Truck, VIN # 1HTWGAAR87J437650 (A51572)
2007 International...
2013 FORD F-150 XL EXTENDED CAB TRUCK (A51406)
2013 FORD F-150 XL...
2015 JLG Triple-L Flatbed T/A Trailer (A50324)
2015 JLG Triple-L...
2013 FREIGHTLINER BUSINESS CLASS M2 VACUUM TRUCK (A51406)
2013 FREIGHTLINER...
2006 Reelmaster Toro 3100D Mower (A50324)
2006 Reelmaster...
KMC 3376 LOT NUMBER 271 (A53084)
KMC 3376 LOT...
